WHAT CAUSES WIND?
In talking about wind damage, we should first cover some basics.
As air in warmer areas rises, cooler air moves in to replace it. It’s this replacement air that we experience as wind. The force that pulls the replacement air is called “convection.” Convection can cause both updrafts and downdrafts, which create wind with different characteristics, including varying:
Hurricanes
This process happens on both large and small scales. At the large end of the scale are hurricanes in which the area of strong winds might be between 25 and 150 miles wide. Hurricanes are classified according to wind speed:
Tornadoes
Many other convection-related wind events occur both with and without storms. Another condition that creates winds which can damage roofs is large-scale weather patterns that produce a strong, deep flow of air which passes over a mountain chain.
Forced up out of its natural path by the peaks, the wind seeks to return to its original level. But before settling back into a horizontal flow across the plains, it oscillates through several up-and-down cycles. As you can see in this illustration, these winds will actually bounce several times, and they can cause damage in certain areas with some predictability. If you’re inspecting in an area that fits this description, be looking for wind damage. These winds can slam into the ground at over 100 miles per hour.
You can sometimes spot these areas even when the wind is not blowing.
Over many thousands of years, the area near the base of the foothills where the wind first bounced has developed a trough, with soil scooped out by the wind.
This is often more pronounced below geological features which channel wind, such as canyons.
Learn how to master a roof inspection from beginning to end by reading the entire InterNACHI series: Mastering Roof Inspections.
Take InterNACHI’s free, online Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
