It is important to note that coral snake bites do not result in significant swelling, discoloration or pain, and effects of the venom may take hours to develop.
- Bull snakes have no rattler. When threatened, they will often forcefully vibrate their tails which serves as a warning to potential predators. In dry leaves or grass, this will produce a sound that is quite similar to one emitted by a rattlesnake. Another related indicator is that bull snakes will keep their tails low to the ground while producing ther rattling sound, while most rattlesnakes will elevate their tail while rattling.
- Although the two often have similar patterns, bull snakes are generally cream or pale yellow in color with brown or black markings; rattlesnakes, on the other hand, are typically much darker, depending upon the subspecies.
- The body of a bull snake is more streamlined than that of a rattlesnake. A bull snake will be noticeably thinner and its body will become proportionately narrower down to its tail,
which ends at a defined point. A rattlesnake will appear thicker, particularly in its mid-section, with a more rounded tail due to its rattle.
- The head of a bull snake is nearly identical in size to the upper portion of its body. The head of a rattlesnake, however, is more triangular in shape and is perceptibly wider than its upper body.
- Bull snakes' pupils are circular, while those of rattlesnakes are vertically-oriented. All venomous snakes in North America have vertically-oriented pupils, except for the coral snake.
- Bull snakes lay eggs, while rattlesnakes give birth to live offspring.
Death is uncommon (less than 1% of the reported cases), but in the elderly or very young, death may occur from asphyxia. Seek medical attention if you suspect you have been bitten.
Hobo Spider: This spider is not native to the U.S., but by the mid-1960s, it had become established in Washington, Oregon, Idaho and British Columbia. Current distribution places it also in Montana, northern Utah, and western Wyoming. Although the bite of the hobo spider is initially painless, it can be serious. Hobo spiders are often confused with wolf spiders, which produce a painful but relatively harmless bite. If serious symptoms develop, the victim should seek medical attention.
- Symptoms of bite:
- immediate redness, which develops around the bite;
- after 24 hours, the bite develops into a blister, and after 24 to 36 hours, the blister breaks open, leaving an open, oozing ulceration;
- severe headache;
- temporary memory loss;
- impairment of vision;
- nausea; and
- weakness.
Preventing Spider Infestation
