As is recommended for the installation of other roof-covering materials, it’s important that the manufacturers’ recommendations be followed for installing both concrete and clay tiles. Recommendations may be different for different types of tile and for similar types made by different manufacturers. Recommendations for similar types may change over time. So many tile installation methods have been recommended over the years that describing proper installation methods for all types of tile exceeds the scope of this article series, as well as the requirements of a home inspection.
Unless you have a thorough understanding of the installation requirements for the particular type of tile on the roof you’re inspecting, you should clearly disclaim proper installation. Using your experience and common sense, you can often identify deficiencies of a tile roof, but you want your clients to have the clearest possible understanding of the limitations of your inspection. You want your clients to have realistic expectations. If they want a more definitive inspection, they can hire a qualified contractor. Unless you make clear the limitations of your inspection, your clients may not realize the potential need for further inspection, and you may incur liability.
According to modern building codes, concrete and clay tiles should be installed according to the manufacturers’ instructions, based on the following:
As an inspector, you’ll be looking at homes of many different ages, and older tile roofs may not comply with modern codes, nor are they required to. A home inspection is an inspection for safety issues and system defects, not code compliance.
When inspecting a tile roof, you’ll be looking to see if the installation method used appears to be adequately protecting the home from moisture intrusion and holding tiles securely in place.
In addition to looking for obvious defects and failures in installation, you’ll be evaluating the condition of the tile, trim, flashing and fasteners. Because tile can have a long service life, it may outlast the fasteners and flashing.
Some jurisdictions, such as cities, counties and states, may have regulations that affect tile installations. If this is the case in the areas where you often inspect, you may want to take time to learn those regulations.
Roof Sheathing
According to modern building codes, concrete and clay tiles may be installed over either solid or spaced roof sheathing.
Minimum Roof Slope
Also, according to modern building codes, concrete and clay tiles may be installed on roofs with slopes of 2:12 and greater, although roofs with slopes of 4:12 and less must have a double layer of underlayment.
Underlayment
The type of underlayment installed beneath concrete and clay tile should conform to the manufacturer’s installation recommendations.
Modern building codes call for underlayment beneath concrete and clay tile to be 30-pound felt or mineral-surfaced roll roofing.
Low-slope conditions, such as roofs with slopes of 2:12 to 4:12, should have a double layer of underlayment beneath all of the tile.
This means that underlayment should be overlapped a minimum of 19 inches, as you see in the photo above.
For slopes greater than 4:12, underlayment must overlap a minimum of 2 inches.
Flashing
Modern building codes have minimum requirements for headwall, sidewall and valley flashing for tile roofs. These requirements may be superseded by the manufacturer’s installation recommendations.
Headwalls and sidewalls should have flashing and counter-flashing, although you’ll often see the exterior wall-covering material used as the counter-flashing. Although it may not be code-compliant, as long as the method used prevents runoff from entering behind the flashing, the method used is effective. Building codes call for flashing to be a minimum of 0.019 inch, but, as an inspector, you’ll have no way of confirming this. If the flashing looks too thin, recommend that proper flashing be confirmed by a qualified contractor.
Modern building codes call for valley flashing to:
For flashing materials, you may see galvanized steel, copper, aluminum and lead.
Flashing at field tiles, such as that used for penetrations, including plumbing stack pipes, combustion vents and skylights, is often bent to fit the profile of the tiles, as you see in the photo above.
Fasteners
Proper fastening of tiles can be difficult to confirm. Tiles may be attached with nails, screws, clips, wire, foam or caulk adhesive, or mortar. Fastening varies with the age of the roof, the type and weight of the tile, basic wind speeds at the home site, the roof’s height, the manufacturer’s recommendations, and jurisdictional requirements.
Some types of tile -- notably, those with lugs that hang from battens and that are installed on roofs with slopes of less than 5:12 -- may require no fasteners at all, or fasteners installed only along the perimeter. Fastening requirements may be different for field, rake and cap tiles.
According to modern building codes:
Learn how to master a roof inspection from beginning to end by reading the entire InterNACHI series: Mastering Roof Inspections.
