Straw-bale construction is a building method that uses bales of straw as structural elements and/or building insulation.
Facts and Figures
While the construction of modern straw homes has seen a recent resurgence, straw has been used in construction on the African plains since the Paleolithic Era. Straw-thatched roofs were common in northern Asia and Europe in past centuries (and many original thatched roofs are still maintained today, especially in the U.K.), and straw homes were built in Germany 400 years ago. American Indian teepees were typically insulated for winter with loose straw placed between the outer cover and inner lining. Early settlers of the American West used straw as thatch roofing, but it wasn’t until the 1890s that the mechanical baler allowed straw to be used as construction building blocks. Their popularity waned by 1940 but re-emerged in the 1970s. Straw bale homes were finally recognized by some building codes by the 1990s.
Straw bales may also become moist before construction is completed, especially if they weren’t stored in a dry, protected area prior to or during construction. It is critical that builders inspect straw for moisture before it is used.
Additional Construction and Inspection Tips
