by Nick Gromicko, CMI®
CO spillage may occur for any of the following reasons:
Spill Switch Testing
Spill switches should be tested periodically. Remember to provide adequate ventilation while testing, or CO vapors might become overwhelming and cause personal injury. To do this, first turn off the appliance. Then, remove the vent from the flue and block the vent with sheet metal, plywood, rags or some other material. Turn the appliance on and wait; the switch should trip within 10 minutes, according to the American National Standards Institute, although many manufacturers have shorter time requirements. The switch should be replaced if it doesn’t open within the time specified by the manufacturer. To reset the switch, press the button between the switch’s wires.
Spill Switch Inspection
InterNACHI inspectors can test for the following spill switch defects:
Other Tips
