Consider the following advantages offered by soy-based insulation:
Typically, soy-based insulation is applied by trained technicians who arrive with tanks. Homeowners, however, can find the material in their local hardware store for around $6 per can and apply it themselves. Either way, a water spray is used to apply soy-based insulation, which subsequently expands to roughly 100 times its original volume, forcing itself into nearby spaces and crevices while it hardens.
Soy-based insulation is available in the following two forms:
This new type of insulation is more expensive than fiberglass and most other traditional types of insulation. The reason for this premium is that soy-based insulation is still a niche market, having yet to experience the mass production that deflated the price of fiberglass. And, of course, many environmentalists will pay more for a sustainable, renewable form of insulation.
All spray-foam insulation, including soy-based, is green in the sense that it can help homeowners dramatically reduce their energy bills. Soy-based insulation is greener than other insulation material because soy is a renewable resource. But don't be fooled into thinking that soy-based insulation is 100% soy, or even mostly made from soy; as much as 85% of soy-based insulation may be petroleum-based. And, of greater value than the type of insulation used is that the homeowner should first obtain an energy audit performed by an InterNACHI inspector in order to gain a better understanding of what insulative measures should be taken.
