the primary road(s) leading to the property;
road and property address signs;
automatic gates;
the driveway;
property slope;
property vegetation;
the yard within 100 feet of the home (aka the defensible space);
the home’s exterior, including:
roof-covering materials, gutters, and penetrations, including vents, the drainage system, and chimneys;
exterior walls; and
window and door exteriors; and
the electrical service conductors.
Describe:
the access road and driveway surfacing materials and maintenance protocol;
the lot size (when available from documentation);
any bridge materials, clearances, and certifications;
any gate’s horizontal and vertical clearances;
any automatic gate’s means of entry;
any horizontal and vertical clearance limitations of the driveway;
the smallest driveway’s inside turn radius (where applicable);
the property fuels of concern (type and general density);
the absence, presence, and location of a water source approved for firefighting;
the roof-covering and drainage system materials;
the exterior wall construction method and exterior wall-covering materials;
the onsite electrical service conductors as being above- or under-ground;
the presence of outbuildings within 30 feet of the home, including the combustibility of their exterior materials; and
the presence of potential hazards to emergency responders (combustible gas/liquid fuel tanks, hazardous chemicals, etc.).
Photo-document:
the entry to the property, including the address sign;
any bridges and posted weight limitations;
any automatic gate showing key box location (if present);
the property’s slope with respect to the home;
the area included within the defensible space;
the home elevations and roof slopes;
all attached structures (decks, balconies, porches); and
any potential hazards to emergency responders (combustible gas/liquid fuel tanks, hazardous chemicals, etc.).
The inspector is not required to:
verify compliance with any regulations, codes, standards, or building permits;
verify the fire-rating of the roof-covering materials;
make property entry recommendations;
enter a home or outbuilding;
inspect outbuildings or ancillary structures;
inspect or report on systems or components that are not readily visible;
inspect for, sample for, or identify any environmental hazards;
make any purchase recommendations; or
include in the report items listed as being outside the scope of the inspection or these Standards.
