Because natural disasters are sometimes unpredictable and unavoidable, it is important for homeowners to take necessary
precautions to reduce the damage to their homes. However, when returning to a home that’s been flooded after a natural disaster, such as a hurricane, tornado or flood, homeowners should be aware that their house may be contaminated with mold or sewage, which can cause health problems. The following steps should be considered when re-entering a home after a natural disaster.
When You First Re-Enter Your Home
If there is standing water in your home and you can turn off the main power from a dry location, then go ahead and turn off the power, even if it delays cleaning. If you must enter standing water to access the main power switch, then call an electrician to turn it off instead. Never turn the power on or off yourself, or use an electric tool or appliance while standing in water.
Additionally:
- Have an electrician check the
house’s electrical system before turning the power on again.
- If the house has been closed up for
several days, enter briefly to open the doors and windows to let the house air out
for a while (at least 30 minutes) before you remain for any length of time.
- If your home has been flooded and
has been closed up for several days, assume that your home has become
contaminated with mold.
- If your home has been flooded, it
also may be contaminated with sewage.
Drying
Out Your House
If flood water or stormwater has entered the home, dry it out as soon as possible. To do so, the following steps should be taken:
- If you have power and an
electrician has determined that it’s safe to turn it on, use a wet-dry shop
vacuum (or the vacuum function of a carpet steam cleaner), an electric-powered
water-transfer pump, or a sump pump to remove the standing water. When operating the equipment in wet areas, be sure to wear rubber boots.
- If you do not have electricity, or
it is not safe to turn it on, you can use a portable generator to power the equipment to remove standing water. Note: If you must use a gasoline-powered
pump, generator, pressure washer, or any other gasoline-powered tools to clean
your home, never operate the gasoline engine inside the home, basement, garage,
carport, porch, or other enclosed or partially enclosed structure, even if the
windows and doors are open. Such improper use can create dangerously high
levels of carbon monoxide and cause carbon monoxide poisoning.
- If weather permits, open the doors
and windows to aid in the drying-out process.
- Use fans and dehumidifiers to remove
excess moisture. Fans should be placed by a window or door to blow the air
outward rather than inward so as not to spread mold spores indoors.
- Have your home’s heating,
ventilation and air-conditioning (HVAC) system checked and cleaned by a
maintenance or service professional who is experienced in mold cleanup before
you turn it on. If the HVAC system was flooded with water, turning on the
mold-contaminated HVAC will spread mold spores throughout the house.
Professional cleaning will kill the mold and prevent mold growth later. When
the service professional determines that your system is clean, and if it is
safe to do so, you can turn it on and use it to help remove excess moisture
from your home.
- Prevent water outdoors from re-entering
your home. For example, rainwater from gutters or the roof should drain away
from the house; the ground around the house should slope away from the house to
keep the basement and crawlspace dry.
- Ensure that the crawlspace has
proper drainage to limit water seepage. Ventilate it to allow the area to dry
out.
Summary
Preparing your home prior to a natural disaster – when it is practical to do so – can help reduce damage to the home, as well as your own stress. Natural disasters, however, are often unpredictable and unavoidable. Re-entering the home, as well as drying it out, can be dangerous and should be conducted with caution. By following these steps, homeowners can better understand how to safely enter, air out, drain, and return to living in their home. And be sure to have your InterNACHI® Certified Professional Inspector® inspect your home after a major storm or flood to assess the damage and make appropriate recommendations.
Information for this article was sourced from the Centers for Disease Control and InterNACHI®.
