Pressure-assist toilets look similar to gravity toilets from the outside, but inside their ceramic tanks, they appear and operate quite differently. As the building’s plumbing fills the tank with water, an air-filled diaphragm inside the tank shrinks accordingly. When the toilet is flushed, the compressed air functions like a spring, pushing the water into the bowl with significantly more force than is created by gravity alone.
Advantages of Pressure-Assist Toilets
Disadvantages of Pressure-Assist Toilets
