- The centrifugal pump was secured to its base and was operating quietly.
- The hair and lint strainer basket was clean of debris.
- The type of pipe was identified.
- Pipes and fittings were not leaking.
- Pipes were supported adequately.
- Pipes were not showing signs of calcification, corrosion or deterioration.
- Air pressure-relief valves were installed on all pressure filter tanks.
- Filter tanks were accessible.
- The filter's brand was identified.
- A clean sight glass or visual outfall of at least 3 feet has been provided.
- The pressurized filter tanks and hair and lint traps were not leaking and were properly sealed.
- All piping, filters and components that are part of the system were labeled, tagged, color-coded or otherwise identified.
- A spa (indoor hot tub) was installed.
- The spa was operational.
- No physical damage was apparent at the spa.
- A spa timer was installed and not reachable by a spa user.
- The emergency shut-off switch for the spa was installed and clearly labeled.
- The return drains at the bottom of the spa were installed.
- The spa appeared clean and adequately maintained.
- Safety signs were installed around the pool and spa.
- A throwing rope and attached ring buoy were installed near the pool.
- A telephone was installed near the pool.
- The HVAC system for the pool and spa area was functional.
- The thermostat was of a digital type and was functioning.
- Storage rooms, the boiler room, and other doors were labeled with safety indications.
- The fire extinguisher had not been inspected regularly. It had not been inspected for years. This is a safety hazard.
- The water fountain functioned and it was secured to the wall.
- The fixtures, toilets, showers, doors, and interior surfaces in the men's and women's bathrooms adjacent to the pool and spa facility were operational.
- All windows were operational.
- All doors were operational and had no visible trip hazards.
- The exits signs, alarms, emergency lights, and related systems were tested by a third-party contractor.
Pools and spas can be relaxing and therapeutic additions to any home or multi-unit housing structure, but only if they're safe and properly maintained. Providing comprehensive Pool & Spa Inspections can increase the users' safety and enjoyment, as well as provide inspectors with a profitable revenue stream.
