by Nick Gromicko, CMI®
A pool alarm is a safety feature designed to alert adults when unsupervised children enter a pool. There are a number of different designs available, but none is foolproof.
Inspectors should become acquainted with these innovations, and inform their clients of the main types available, and the potential dangers of doing without.
Drowning remains the second leading killer of children under the age of 14 and, in many Sunbelt states, drowning tops the list. Approximately 350 children under the age of 5 drown in swimming pools annually, mostly in residential settings. Many of these deaths occur when unsupervised children enter a pool and are unable to swim or exit, resulting in drowning or near-drowning within minutes. In these situations, pool alarms may have reduced the response time of adults, perhaps saving the child.
In December 2007, the Virginia Graeme Baker Pool and Spa Safety Act took effect, which created a voluntary grant program that encourages states to pass legislation for pool and spa safety. The bill requires states to write laws that call for pool alarms, as well as door alarms, pool covers, and self-closing/self-latching gates. Currently, however, only California, Connecticut and New York have passed such legislation.
Pool Alarm Types
- surface wave sensor: This type of sensor floats on the water and incorporates an electrical circuit that includes two contacts. One of these contacts rests in the water while the other is adjusted to remain above the water's surface. When a surface wave touches the above-surface contact, the electrical circuit is completed, causing an alarm to sound. Sensitivity can be increased or decreased by moving the above-surface contact closer or further from the water surface.
- sub-surface disturbance sensor: Mounted to the pool wall below the water surface, this type of sensors is activated by wave-induced pressure changes. One design relies on the movement of a magnetic float below a magnetic sensor, while another design relies on a pressure-sensitive switch. Sub-surface alarms can also be used in conjunction with solar covers, whereas the surface wave-sensor alarms cannot.
- wristband: This device is worn around the child’s wrist and it cannot be removed without a key. The alarm will activate when the wristband becomes wet, which creates opportunities for false alarms, such as when the child washes his or her hands, or walks in the rain.
In 2000, the U.S. Consumer Product Safety Commission (CPSC) staff conducted a review of commercially available swimming pool alarm systems designed to detect water disturbance or displacement. The CPSC staff evaluated surface wave sensors, sub-surface disturbance testers, and the wristband. Testers concluded that the sub-surface pool alarms generally performed more consistently for true alarms than the other designs, which were more likely to emit false alarms.
Since pool alarms are not foolproof and they rely on someone remembering to activate them, they should not be depended upon as a substitute for supervision, or for a barrier completely surrounding the pool. Pool alarms should also be used in conjunction with other types of alarms, such as gate alarms, perimeter alarms, and window and door alarms. Even some pet doors come equipped with alarms, owing to the recent attention given to the 100 or so documented accidents where a child escaped to a pool through a pet door. Pool alarms are thus one protective layer of many, none of which is sufficient as a sole preventative measure against child drowning.
Pool alarms can be used to save dogs and cats, too. Data show that one of every 1,027 pets drowns in pools each year, which is a statistically higher risk than the drowning threat for small children. The reason here is obvious: pets are more likely to be allowed to roam free and unsupervised compared to small children, especially in rural areas where nearby traffic is not a danger. Also, pool fences may thwart children, while dogs and cats can jump or climb their way to the other side. Not all dogs are good swimmers, though, and even healthy dogs that are used to swimming in ponds might not be able to lift themselves out of a pool when they tire.
In summary, pool alarms are useful safety features, although inspectors should recommend to their clients that they be used strictly in conjunction with other strategies.
