An outhouse is a small, stand-alone structure that contains a waterless toilet that does not flush or empty into a sewer or septic system. These cost-effective, decentralized waste-management structures are primarily used in low-income urban communities and rural areas, especially in the developing world.
Outhouses function differently than septic systems partly because its waste pit is not filled with standing water, although urine provides small amounts of moisture. The aerobic environment of an outhouse pit (in contrast to the anaerobic environment of a sewer) allows for insects, amoebas, molds and earthworms to flourish, turning waste matter into ecologically safe compost. Decomposition is generally effective as long as the input of new waste does not exceed the capacity for it to be consumed and decontaminated, although the process is typically slow due to the layering of waste material.
Odor Control
The decomposition of waste naturally leads to the emission of odorous gasses, such as methane and hydrogen sulfide. The odor will be minimized if these gasses are allowed to escape through a vertical vent tube, which is typically installed in the corner of the outhouse structure. Ventilation of the outhouse also helps prevent overheating during the summer months. During the day, the sun’s heat forces a convection cycle whereby fresh air enters the outhouse and expels warm pit gasses out the vent tube. Vents can be constructed of a 4-inch or larger metal or plastic pipe, or 1x6 boards framed into a rectangle.
Homeowners can reduce outhouse gasses by adding the following materials:
Hazards
InterNACHI inspectors may check for the following outhouse hazards:
Additional Precautions
