Mastering Roof Inspections: Personal Protective Equipment
As a home inspector, you face a number of different types of potentially dangerous conditions while you’re working. By using certain types of personal protective equipment, you can reduce the chances of injury.
Fall Protection
One of the greatest dangers faced by anyone walking a roof is falling off the roof.
Using fall protection can save your life.
Fall protection starts with an anchoring point into which a lanyard can be clipped.
An anchoring point is typically a ring attached to a metal strap that can be nailed to the roof.
Walking the Roof
You will always do a better job of inspecting a roof if you walk it. There’s no substitute for being able to get a close look at the entire roof.  Sometimes, roofing materials need to be touched to be properly evaluated.
If you do decide to walk the roof, in order to do so safely, the roof should be dry.  You should be wearing soft-soled, high-traction footwear. Crepe-soled boots are a good choice, and so are sneakers with soft, rubber soles. You can also use roof-walking boots.
These boots are made by Cougar Paws and really grip the surface. They have replaceable, high-traction soles which are held to the bottom of the boot by Velcro.
When the sole wears out, it can be easily replaced with a new one. The soft sole can also help limit
damage when you walk roofs covered with fragile materials, such as old, brittle wood shingles or tile.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
