There is a cliché about pictures that you’ve probably already thought of. But if you’re using a thousand words to describe a problem, you need to be charging more money because it is going to take you a long, long time to produce that report. It's better to include a few photos.
Digital Cameras
Don’t use a film camera. Modern inspection software is designed to allow you to easily incorporate digital photos into your inspection report.
By using a digital camera, you can choose low-image resolution so that you can keep the image small, and many photos can be easily emailed at one time. Or, you can use high-resolution so that you can later zoom in to look at details without reducing the quality of the image.
Depending on the type and size of digital storage card you use, you can shoot and store thousands of photos, and you don’t have to wait for them to be developed. Many digital cameras will also shoot video.
Best of all, they’re inexpensive. You can get a fairly good camera for less than $200.
Some digital cameras are more user-friendly than others.
FEATURES
Telephoto Lens
One good feature to have is a strong built-in telephoto lens, so that you can zoom in close on distant objects. For this, your camera should also have electronic image stabilization, so that those long shots won’t be blurry from your hand shaking. Even your heartbeat can shake the camera when you’re zoomed all the way in.
There are two different kinds of zoom: optical and digital. Using a camera with a strong optical zoom will give you better images than when you use a strong digital zoom.
This image was taken zoomed fully out or “wide.”
This image was taken zoomed fully in or “narrow,” using a camera with an 18x optical zoom.
Macro
Flash
A good, strong flash is also a plus so that you can shoot easily in attics, crawlspaces, and down the chimney flue.
When you shoot toward reflective surfaces, glare from the flash can ruin the image. One way to avoid this is to take the shot from an angle instead of straight on. It may also help to back away from the subject and zoom in.
Learn how to master a roof inspection from beginning to end by reading the entire InterNACHI series: Mastering Roof Inspections.
Take InterNACHI’s free, online Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
