by Nick Gromicko, CMI®, Alan Nguyen and Kate Tarasenko
Mold is a byproduct of the breakdown of organic matter, such as plants, wood, and even food and certain beverages. The problem posed to humans by mold is their spores, which can be released into the air and land on damp surfaces indoors, where they will continue to grow, if the conditions are right. Mold growth left unaddressed can quickly spread and result in damage to the structure of a home. More importantly, mold can compromise the respiratory health of susceptible individuals. Although testing for mold falls outside InterNACHI's Residential Standards of Practice, home inspectors can benefit from getting trained in mold testing and offering this valuable – and sometimes life-changing – service to their clients.
Licensing or Certification Requirements for Mold Testing
Before embarking on training in order to offer mold testing services, be sure to check with your state for its requirements for certification or licensing. Some states that require home inspectors to be licensed also require mold inspectors or assessors to be licensed, such as Florida. But there are also states that don't require home inspectors to be licensed but do require mold testers to be licensed, including Ohio.
Mold Inspections and Home Maintenance
A mold inspection starts as a home inspection, which is a non-invasive, visual examination of the home's interior and exterior, and its various systems and components.
The scope of a mold inspection requires particular knowledge of HVAC systems, roofs, the exterior, and plumbing systems. Musty odors, moisture intrusion via a roof or plumbing leak, or even evidence of suspected mold can warrant a mold inspection.
Once mold gets a foothold, it cannot always be completely eradicated, so the best cure is prevention. Homeowners must be vigilant about checking for leaks both inside and outside, and making sure their home is free of conducive conditions – the main culprit being water. For instance, firewood stacked up against the side of the house can retain moisture from dew, rain and snow. Leaks should be fixed as soon as possible. And indoor humidity and moisture should be controlled by making sure appliances, such as the clothes dryer and dishwasher, are vented properly, and that the vents themselves are operating as they should. Windows are another place prone to mold growth if the frames are old and damaged, or the seals on the panes have failed. And basements and crawlspaces are notorious breeding grounds for mold, especially if they're used only for storage, the windows are old or damaged, and/or the area experiences occasional flooding. All of these things fall under the category of home maintenance, which InterNACHI® Certified Professional Inspectors® can educate their clients about.
Testing
Mold testing involves two main methods: air sampling and surface sampling. Both types require analysis by a certified laboratory. In some cases, the local health department can test the mold samples. But it's more common for a private lab to perform the analysis and generate the results in a report, and the cost is usually included in the price of the test kit.
Along with the sampling equipment, the tools commonly used by home inspectors for a mold inspection of the home's interior include the following:
Air Sampling
Air sampling is conducted indoors and outdoors using spore traps or canisters. This less-common method is used for homes in areas suspected of having high concentrations of mold spores. The outdoor samples are used to create a control or baseline to determine the level of contamination, and then the control is compared to the indoor samples. When taking the outdoor sample, the home inspector should be alert to environmental conditions that can affect the results, such as wind, rain, snow, and fluctuating temperatures.
Surface Sampling
Surface sampling is the more common and easiest method for testing for indoor mold.
Here are some methods of surface sampling that can be performed:
PPE
When taking samples of mold or suspected mold, it's important for home inspectors to be protected by wearing suitable personal protective equipment (PPE). Goggles, a respirator, gloves, a Tyvek® suit, and boot covers can be worn to protect clothing, as well as the eyes, nose and mouth.
Summary
When it comes to mold, prevention is the best way to combat it. A damp or musty smell is a likely indicator and should be investigated thoroughly. Homeowners should be encouraged to locate and repair all plumbing leaks and sources of water intrusion, which can quickly lead to mold growth. Home inspectors can get training to identify mold, as well as conducive conditions and where mold is likely to grow. Becoming certified as a mold inspector assures your clients that you understand the standards and safe practices for sampling and reporting on mold.
Share your ideas about mold testing and join the discussion with other InterNACHI members on our online forum.
This article was sourced from InterNACHI® and the EPA. Special thanks to InterNACHI® member Ray Kline of All Phase Inspections for his contributions to this article.
Take InterNACHI's free online How to Perform Mold Inspections Course
Take InterNACHI's free online How to Inspect for Moisture Intrusion Course
Take InterNACHI's free online Advanced Mold Inspections Course
After taking these courses, be sure to join IAC2, the International Association of Certified Indoor Air Consultants!
Mold Inspection Standards of Practice
Air Sampling for Mold Inspections
How Home Inspectors Can Upsell Mold Testing
Mold, Moisture, and Your Home (consumer article)
