DAMAGING CONDITIONS
The important properties of coatings for metal roofing products include resistance to:
- color-fading, as UV degrades pigments;
- chalking, as oxidation leaves a chalk-like substance on the surface;
- moisture-related problems;
- abrasion;
- staining;
- corrosion, the rate of which is increased by pollution and salt spray;
- cracking caused by flexing; and
- damage from solvents and acids.
Most of these properties are tested according to ASTM standards during manufacturing, which you are not responsible for confirming.
Surface Defects
Surface defects can be caused by the manufacturing process, and some may result in premature failure. Other causes include the following.
- Blistering is caused by the expansion of gas in or under the paint.
Courtesy of the National Coil-Coating Association
- Catenary or oven scratches show as streaks in the paint parallel to the panel's length.
- Dirt lines appear parallel to the panel's length and are caused by particles trapped between the applicator roll and the strip. They can also be caused by air bubbles trapped in the paint.
- Paint splatter can happen during the manufacturing process.
- Pinholes are usually caused by degassing in the metal coating, resulting in tiny holes that penetrate through the paint to the metal.
- Skipping is an irregular paint application caused by improper contact between the applicator roll and the strip.
- Water staining is a type of white rust that forms on the surface of aluminum and is caused by moisture.
Oil-Canning
“Oil-canning” is a term used to describe ripples in metal panel roofs. It’s seldom seen in metal shingle-type roofs, corrugated or heavily formed roofs, which is a type of roofing that has extreme bends and folds pressed into it as part of its architectural profile.
Oil-canning can have a variety of causes, including problems with the steel-coil manufacturing during panel fabrication, such as when one part of the metal coil (the center or one side) is longer than the other parts. It can be caused by installation. You don’t need to identify the cause. Oil-canning is a cosmetic issue unless it’s caused by structural movement, in which case it may result in leakage at some point. Unless your employer says otherwise, you probably won’t mention it in your report.
