In addition to covering defects from manufacturing, installation, and natural weathering, the articles also cover the accurate identification of wind and hail damage.
Although these articles were written primarily for home inspectors, the criteria used to evaluate roofs is also relevant for insurance and roofing industry professionals -- both of whom we worked with closely in developing this series -- to determine functional versus cosmetic damage, and whether damage was caused by wind, hail, weathering, improper installation, or manufacturing defects.
Article Index for
Mastering Roof Inspections: Roof Framing, Part 1
Accessing the Roof
Mastering Roof Inspections: Accessing the Roof, Part 1
Mastering Roof Inspections: Accessing the Roof, Part 2
Mastering Roof Inspections: Accessing the Roof, Part 3
Mastering Roof Inspections: Accessing the Roof, Part 4
Mastering Roof Inspections: Accessing the Roof, Part 5
ASPHALT SHINGLE COMPONENTS
Mastering Roof Inspections: Asphalt Composition Shingles, Part 1
ORGANIC SHINGLES
Mastering Roof Inspections: Asphalt Composition Shingles, Part 2
Asphalt Composition
Mastering Roof Inspections: Asphalt Composition Shingles, Part 3
Back-Surfacing
Granules
Mastering Roof Inspections: Asphalt Composition Shingles, Part 4
Adhesive Strips
Cellophane Strips
Mastering Roof Inspections: Asphalt Composition Shingles, Part 5
TYPES of ASPHALT SHINGLES
Mastering Roof Inspections: Asphalt Composition Shingles, Part 6
PERFORMANCE STANDARDS
Mastering Roof Inspections: Asphalt Composition Shingles, Part 7
Variations Among Asphalt Composition Shingles
Mastering Roof Inspections: Asphalt Composition Shingles, Part 8
ASPHALT SHINGLE WARRANTIES
Mastering Roof Inspections: Asphalt Composition Shingles, Part 9
FIELD-CHECKING SHINGLE THICKNESS
Mastering Roof Inspections: Asphalt Composition Shingles, Part 10
PROBLEMS WITH ASPHALT SHINGLES
Mastering Roof Inspections: Asphalt Composition Shingles, Part 11
LONG-TERM SERVICE LIFE
Proper Installation
Shingle Quality
Multiple Layers
Directional Orientation
Roof Design
Mastering Roof Inspections: Asphalt Composition Shingles, Part 12
Climate Zone
Thermal Cycling
Shingle Color
Home Site Conditions
Elevation
Quality of Maintenance
Mastering Roof Inspections: Asphalt Composition Shingles, Part 13
SOURCES Of DAMAGE
Installation
Building Codes
Mastering Roof Inspections: Asphalt Composition Shingles, Part 14
UNDERLAYMENT
The IRC and Manufacturers' Recommendations
Pitch Requirements
Underlayment Installation Requirements
Steep-Slope Roofs
Low-Slope Roofs
Fasteners
Mastering Roof Inspections: Asphalt Composition Shingles, Part 15
UNDERLAYMENT in VALLEYS
Mastering Roof Inspections: Asphalt Composition Shingles, Part 16
FLASHING
IRC Requirements
ROOF-WALL INTERSECTIONS
Headwall Flashing
Mastering Roof Inspections: Asphalt Composition Shingles, Part 17
SIDEWALL FLASHING
Step-Flashing
Counter-Flashing
Sidewall Defects
Wall-Covering Clearance
Mastering Roof Inspections: Asphalt Composition Shingles, Part 18
COUNTER-FLASHING
Counter-Flashing at Brick Walls
Counter-Flashing at Stone Walls
Mastering Roof Inspections: Asphalt Composition Shingles, Part 19
Kickout Flashing
Changes in Roof Slope or Direction
Valleys
Hips
Mastering Roof Inspections: Asphalt Composition Shingles, Part 20
Changes in Pitch
Drip-Edge Flashing
Roof Penetrations
Skylights
Mastering Roof Inspections: Asphalt Composition Shingles, Part 21
Mechanical Attachment Points
Mastering Roof Inspections: Asphalt Composition Shingles, Part 22
SHINGLE INSTALLATION METHODS
Slope Limitations
Valley Types
Open Valleys
Closed Valleys
Cut Valleys
Woven Valleys
Mastering Roof Inspections: Asphalt Composition Shingles, Part 23
RACKING
Mastering Roof Inspections: Asphalt Composition Shingles, Part 24
FASTENERS
Disclaim Proper Fastening
Jurisdictional Requirements
Fastener Type
Nails
Mastering Roof Inspections: Asphalt Composition Shingles, Part 25
Depth of Penetration
Fastener Placement
Conventional Patterns
High-Wind Patterns
Mastering Roof Inspections: Asphalt Composition Shingles, Part 26
Substrate Holding Power
Hand-Sealing Shingles
Checking for Proper Fastening
Checking Shingle Bond
Mastering Roof Inspections: Asphalt Composition Shingles, Part 27
RE-ROOFING OVER EXISTING SHINGLES
Reduced Impact Resistance
Bridging and Nesting
INCREASING ROOF WEIGHT
Mastering Roof Inspections: Asphalt Composition Shingles, Part 29
ASPHALT SHINGLE WEATHERING
Shingle Quality
Structure Orientation
Degree of Roof Slope
Climate
Thermal Cycling
Roof Color
Elevation
Roof Structure Ventilation
ASPHALT SHINGLE LIFESPAN
Packaging
Installation
Slow, Prolonged Aging
Accelerating Deterioration
Mastering Roof Inspections: Asphalt Composition Shingles, Part 30
Moisture
Effects of Moisture
Ice Dams
Mastering Roof Inspections: Asphalt Composition Shingles, Part 31
The Asphalt Layer
Volatiles
Mastering Roof Inspections: Asphalt Composition Shingles, Part 32
DUCTILITY
Filler
Polymers
Transition Temperature
Mastering Roof Inspections: Asphalt Composition Shingles, Part 33
GRANULE LOSS
New Roofs
Uniform Granule Loss
Slope Orientation
Batch Problems
Flaking
Foot Traffic
Mastering Roof Inspections: Asphalt Composition Shingles, Part 34
ASPHALT SHINGLE MANUFACTURING DEFECTS
Inadequate Asphalt Coating
Blister Pops
Spliced Shingles
Mastering Roof Inspections: Asphalt Composition Shingles, Part 35
COSMETIC ISSUES
Visual Issues
Shingle Colors
Mixing Shingle Lots
Oil and Dust
MANUFACTURING VARIATIONS
Granule Tilt
Machine-Speed Granule Tilt
Granule Sizing
Machine-Speed Granule Blend
Granule Embedment
Mixing Algae and Non-Algae-Resistant Shingles
Mastering Roof Inspections: Asphalt Composition Shingles, Part 36
MECHANICAL DAMAGE
Tool Damage
Impact
Scuffing
Marring
Intentional Damage
Mastering Roof Inspections: Asphalt Composition Shingles, Part 37
SUBSTRATES
Wood Board
Plywood and OSB
Sheathing Thickness
Modern Standards
H-Clips
Mastering Roof Inspections: Asphalt Composition Shingles, Part 38
SHINGLE SPLITTING
Splitting vs. Cracking
THERMAL SPLITTING
Roof-Structure Assembly
Splitting Over Shingle Joints
Mastering Roof Inspections: Asphalt Composition Shingles, Part 39
SUBSTRATE MOVEMENT
Sheathing Expansion and Contraction
Initial Conditioning
Seasonal Fluctuation
Shingle Splitting
Shingle Buckling
Mastering Roof Inspections: Asphalt Composition Shingles, Part 40
BUILDING DESIGN
Roof-Structure Ventilation
Cooling Season
Heating Season
Moisture Problems
Mold Growth
Ice Dams
Mastering Roof Inspections: Asphalt Composition Shingles, Part 41
ENVIRONMENTAL DAMAGE
Tree Damage
Animal Damage
Biological Growth
Algae
Preventing Algae Growth
Mastering Roof Inspections: Asphalt Composition Shingles, Part 42
Biological Growth
Moss
Lichen
"Tobacco-Juicing"
Mastering Roof Inspections: Asphalt Composition Shingles, Part 43
HAIL DAMAGE
Impact Resistance
Characteristics of Damage
Mastering Roof Inspections: Asphalt Composition Shingles, Part 44
Mat
Asphalt Composition
Lack of Studies
UV Radiation
Conclusion
Mastering Roof Inspections: Asphalt Composition Shingles, Part 45
DAMAGE to the GRANULE LAYER
Functional Damage
Asphalt Quality
Hailstone Properties
"Hitchhikers"
Wind-Driven Hail
Mastering Roof Inspections: Asphalt Composition Shingles, Part 46
Area of Impact
Angle of Impact
Temperature
Substrate Support
Hail Damage vs. Blisters
Mastering Roof Inspections: Asphalt Composition Shingles, Part 47
Material Properties
Intentional Damage
Mastering Roof Inspections: Asphalt Composition Shingles, Part 48
Ball-Peen Hammers
Characteristics of Damage by Ball-Peen Hammers
Claw Hammers
Coins
Golf Balls
NON-INTENTIONAL, NON-HAIL DAMAGE
Tool and Equipment Damage
Mastering Roof Inspections: Asphalt Composition Shingles, Part 49
WIND DAMAGE
Wind-Resistance Standards
Wind Factors
Failure Modes
Tab Uplift
Shingle Pull-Over
Creasing and Tearing
Mastering Roof Inspections: Asphalt Composition Shingles, Part 50
Blow-Off
Adhesive Strips
Transfer
Inflation
Mastering Roof Inspections: Asphalt Composition Shingles, Part 51
Rake Edges
Aging
Mastering Roof Inspections: Asphalt Composition Shingles, Part 52
TYPES of SHINGLE DAMAGE
Creased or Broken Tabs
Debris
Shingle Blow-Off
Mastering Roof Inspections: Asphalt Composition Shingles, Part 53
FASTENERS
Fastener Types
Staples
Nails
Proper Fastener Installation
Fastener Placement
The Holding Power of the Substrate
Inadequate Penetration
Mastering Roof Inspections: Asphalt Composition Shingles, Part 54
INDIVIDUAL SHINGLE REPLACEMENT
Performing the Inspection
On the Roof
Checking Shingle Bonding
Shingle Fastening
Shingle Problems
Flashing Problems
Underlayment Problems
Mastering Roof Inspections: Asphalt Composition Shingles, Part 55
Attic Area Roof Inspection
Penetrations
Poor Connections
Mastering Roof Inspections: Attic Area Roof Inspection
Attic Ventilation Systems
Cools the Roof
Cools the Living Space
Removes Moisture
ACTIVE VENTILATION SYSTEMS
Thermostatically Controlled Fan
Whole-House Fan
Backdrafting
Mastering Roof Inspections: Attic Ventilation Systems, Part 1
PASSIVE SYSTEMS
Soffit Vents
Gable Vents
Roof Vents
Wind Turbine
Mastering Roof Inspections: Attic Ventilation Systems, Part 2
Continuous Ridge Vent
Adequate Ventilation
RADIANT BARRIERS
Mastering Roof Inspections: Attic Ventilation Systems, Part 3
Flashing
IRC Requirements
Corrosion
Mastering Roof Inspections: Flashing, Part 1
HEADWALL FLASHING
SIDEWALL FLASHING
Step Flashing
Tile Requires Pan Flashing
Step Flashing Sizes
Mastering Roof Inspections: Flashing, Part 2
COUNTER-FLASHING
Counter-Flashing at Brick Headwalls and Sidewalls
Mastering Roof Inspections: Flashing, Part 3
KICKOUT FLASHING
Mastering Roof Inspections: Flashing, Part 4
VALLEYS
Open Valleys
Closed Valleys
Mastering Roof Inspections: Flashing, Part 5
CHANGES in PITCH
DRIP EDGE
Mastering Roof Inspections: Flashing, Part 6
Hail Damage
Hail Damage: Where and When?
Mastering Roof Inspections: Hail Damage, Part 1
DEFINING HAIL DAMAGE
Functional Damage
Cosmetic Issues
Mastering Roof Inspections: Hail Damage, Part 2
HAIL DAMAGE CHARACTERISTICS
IMPACT ENERGY
Size
Mastering Roof Inspections: Hail Damage, Part 3
Density
Velocity
Variation Within Storms
Mastering Roof Inspections: Hail Damage, Part 4
Shape
Angle of Impact
Directionality
Mastering Roof Inspections: Hail Damage, Part 5
Type of Roof-Covering Material
Roofing Material Condition
Part of the Roofing Material Hit
Nature of the Substrate
Temperature of the Roofing Material
Mastering Roof Inspections: Hail Damage, Part 6
FORENSICS of HAIL DAMAGE
COLLATERAL DAMAGE
Spatter
SOURCE of DAMAGE
Mastering Roof Inspections: Hail Damage, Part 7
Directionality
Random Fall Pattern
Intentional Damage
Age of Damage
Mastering Roof Inspections: Hail Damage, Part 8
IDENTIFYING COLLATERAL DAMAGE
Elevation Damage
Gutters and Downspouts
Mastering Roof Inspections: Hail Damage, Part 9
Elevation Damage
Windows and Doors
SIDING
Vinyl Siding
Mastering Roof Inspections: Hail Damage, Part 10
Fencing
Painted Surfaces
Air-Conditioning Units
Electrical Panels
Window Well Covers
Directional Clues
Mastering Roof Inspections: Hail Damage, Part 11
HAIL DAMAGE on the ROOF
Test Squares
Number of Hits
Slope/Roof Replacement
Disagreements
Resolving Disagreements
Mastering Roof Inspections: Hail Damage, Part 12
Metal Roofs
Structural and Architectural Metal Roofing
Energy State of Metals
Mastering Roof Inspections: Metal Roofs, Part 1
CORROSION
Galvanic Crevice Corrosion
Corrosion
Filiform Corrosion
Mastering Roof Inspections: Metal Roofs, Part 2
METALS USED FOR ROOFING
Naturally Weathering
Copper
Aluminum
Mastering Roof Inspections: Metal Roofs, Part 3
Steel
Coated Steel
Galvanized Coating
Galvalume®
Mastering Roof Inspections: Metal Roofs, Part 4
BARRIER COATINGS
Types of Paint
Mastering Roof Inspections: Metal Roofs, Part 5
DAMAGING CONDITIONS
Surface Defects
Mastering Roof Inspections: Metal Roofs, Part 6
METAL ROOF INSTALLATION
Mastering Roof Inspections: Metal Roofs, Part 7
FASTENING METHODS FOR METAL PANEL ROOFS
Mastering Roof Inspections: Metal Roofs, Part 8
METAL SHINGLES
Mastering Roof Inspections: Metal Roofs, Part 9
HAIL DAMAGE to METAL ROOFS
WIND DAMAGE to METAL ROOFS
Mastering Roof Inspections: Metal Roofs, Part 10
Mastering Roof Inspections: Moisture Problems
Mastering Roof Inspections: Personal Protective Equipment
Mastering Roof Inspections: Pests
Mastering Roof Inspections: Photography
Mastering Roof Inspections: Respiratory Protection
Roof Drainage Systems
GUTTERS
Mastering Roof Inspections: Roof Drainage Systems, Part 1
DOWNSPOUTS
Interior Downspouts
Mastering Roof Inspections: Roof Drainage Systems, Part 2
Roof Framing
CONVENTIONAL ROOFS
METAL CONNECTIONS and FASTENERS
Fastener Failure
Mastering Roof Inspections: Roof Framing, Part 2
ROOF TRUSSES
Mastering Roof Inspections: Roof Framing, Part 3
Roof Penetrations
CHIMNEY INSPECTION
FLASHING
Mastering Roof Inspections: Roof Penetrations, Part 1
Cricket
Cap
Flue
Spark Arresters
Attic Chimney
Mastering Roof Inspections: Roof Penetrations, Part 2
VENTS
Mastering Roof Inspections: Roof Penetrations, Part 3
Mastering Roof Inspections: Roof Penetrations, Part 4
SKYLIGHTS
MECHANICAL ATTACHMENT POINTS
Mastering Roof Inspections: Roof Penetrations, Part 5
Roof Styles
Mastering Roof Inspections: Roof Styles
Slate Roofs
Mastering Roof Inspections: Slate Roofs, Part 1
PROPERTIES OF SLATE
Slate Lifespan
Foreign Slate
Mastering Roof Inspections: Slate Roofs, Part 2
SLATE ROOF STYLES
Mastering Roof Inspections: Slate Roofs, Part 3
SLATE DURABILITY
Mastering Roof Inspections: Slate Roofs, Part 4
SLATE FABRICATION and INSTALLATION
Mastering Roof Inspections: Slate Roofs, Part 5
Mastering Roof Inspections: Slate Roofs, Part 6
Mastering Roof Inspections: Slate Roofs, Part 7
Mastering Roof Inspections: Slate Roofs, Part 8
SLATE INSPECTION
Accessing Slate Roofs
Contractor Qualifications
Broken Slate
Snow Guards
Gutters
Cleaning Slate
Slate Roof Design
Mastering Roof Inspections: Slate Roofs, Part 9
Damaged Underlayment
Leaking Slate Roofs
Insects
"Chattering"
Mastering Roof Inspections: Slate Roofs, Part 10
REPAIRING FIELD SLATES
Mastering Roof Inspections: Slate Roofs, Part 11
HAIL DAMAGE to SLATE ROOFS
Mastering Roof Inspections: Slate Roofs, Part 12
COMPOSITE SLATE
Warranties
Mastering Roof Inspections: Slate Roofs, Part 13
Tile Roofs
Side Profiles
Interlocking Tiles
Overlapping Tiles
Butting Tiles
Birdstop
Mastering Roof Inspections: Tile Roofs, Part 1
TILE INSTALLATION
Minimum Roof Slope
Roof Sheathing
Underlayment
Flashing
Fasteners
Mastering Roof Inspections: Tile Roofs, Part 2
CONCRETE TILES
Mastering Roof Inspections: Tile Roofs, Part 3
CONCRETE TILE INSPECTION
Mastering Roof Inspections: Tile Roofs, Part 4
CLAY TILE MANUFACTURING
Mastering Roof Inspections: Tile Roofs, Part 5
CLAY TILE INSTALLATION
Mastering Roof Inspections: Tile Roofs, Part 6
Underlayment
The PURPOSES of UNDERLAYMENT
Mastering Roof Inspections: Underlayment, Part 1
TYPES of UNDERLAYMENT
ASPHALT-SATURATED FELT
Mastering Roof Inspections: Underlayment, Part 2
RUBBERIZED ASPHALT
Mastering Roof Inspections: Underlayment, Part 3
Non-Bitumen Synthetic Underlayment
Mastering Roof Inspections: Underlayment, Part 4
FACTORS AFFECTING UNDERLAYMENT
Climate Types
Roof Design
Mastering Roof Inspections: Underlayment, Part 5
Wind Damage
Mastering Roof Inspections: Wind Damage, Part 1
FACTORS AFFECTING WIND SPEED
Height Above the Ground
Wind Speed
Mastering Roof Inspections: Wind Damage, Part 2
HOW WIND CREATES DAMAGE
Mastering Roof Inspections: Wind Damage, Part 3
WIND DAMAGE CHARACTERISTICS
Mastering Roof Inspections: Wind Damage, Part 4
MITIGATING FACTORS
Mastering Roof Inspections: Wind Damage, Part 5
PERFORMING a WIND-DAMAGE INSPECTION
ELEVATION DAMAGE
Mastering Roof Inspections: Wind Damage, Part 6
Wood Shakes and Shingles
Manufacturing and Application Standards
Preservative-Treated
Mastering Roof Inspections: Wood Shakes and Shingles, Part 1
Grading Authority
Mastering Roof Inspections: Wood Shakes and Shingles, Part 2
UNDERLAYMENT AND INTERLAYMENT
Mastering Roof Inspections: Wood Shakes and Shingles, Part 3
FASTENERS
WOOD ROOF PROBLEMS
Weathering
Extractive Bleeding
Mastering Roof Inspections: Wood Shakes and Shingles, Part 4
Rates of Weathering
Distortion
Checks
Splitting
Mastering Roof Inspections: Wood Shakes and Shingles, Part 5
MECHANICAL DAMAGE
ENVIRONMENTAL PROBLEMS
Mastering Roof Inspections: Wood Shakes and Shingles, Part 6
WOOD ROOF MAINTENANCE
Mastering Roof Inspections: Wood Shakes and Shingles, Part 7
