How to Inspect Manufactured and Mobile Homes Course
Welcome to InterNACHI's free online "How to Inspect Manufactured and Mobile Homes Course." This course is provided by our accredited college at internachi.edu.
Take the free online course now.
Goal:
This course teaches the inspector how to inspect a manufactured or mobile home. It is based upon the U.S. Housing and Urban Development's Standards for Manufactured and Mobile Homes.
Objectives:
Upon successful completion, the student will be able to:
  • Define the differences between manufactured and mobile homes;
  • Inspect the system and components, including body frame, insulation, plumbing, HVAC, electrical, and foundation;
  • List the different types of foundations and supports; and
  • Inspect the accessory buildings and structures; and
  • Communicate to clients indications of defects observed.
Course includes:
  • 12 InterNACHI® CE credit hours;
  • 46,372 words;
  • student book;
  • inspection and writing assignment;
  • research and writing assignment;
  • 143 quiz questions in 13 quizzes;
  • a 75-question final exam (drawn from a larger pool);
  • instant grading; and
  • a downloadable, printable Certificate of Completion.
You will learn the following topics:
  •   Introduction
  •   Mobile vs. Manufactured
  •   8 x 40 or 320
  •   1976
  •   HUD’s Role
  •   Sizes
  •   Transporting
  •   Foundation
  •   Level
  •   Securing the Home to the Foundation
  •   Inspection
  •   Utilities
  • Section 1: General
  •   1.1 Scope
  •   1.2 Definitions
  •   1.3 Data Plate
  •   1.4 Serial Number
  •   1.5 Certification Label
  • Section 2: General Interior Requirements
  •   2.1 Scope
  •   2.2 Definitions
  •   2.3 Light and Ventilation
  •   2.4 Ceiling Heights
  •   2.5 Exit Facilities and Exterior doors
  •   2.6 Exit Facilities and Egress Windows and Devices
  •   2.7 Interior Privacy
  •   2.8 Interior Passages
  •   2.9 Room Requirements
  •   2.10 Minimum Room Dimensions
  •   2.11 Toilet Compartments
  •   2.12 Hallways
  •   2.13 Glass and Glazed Openings
  • Section 3: Fire Safety
  •   3.1 Scope
  •   3.2 Definitions
  •   3.3 Flame Spread Limitations and Fire Protection Requirements
  •   3.4 Kitchen Cabinet Protection
  •   3.5 Carpeting
  •   3.6 Fireblocking
  •   3.7 Requirements for Foam Plastic Thermal Insulating Materials
  •   3.8 Smoke Alarm Requirements
  • Section 4: Body and Frame
  •   4.1. Scope
  •   4.2. Definitions
  •   4.3 General
  •   4.4 Materials
  •   4.5 Structural Design Requirements
  •   4.6 Windstorm Protection
  •   4.7 Resistance to Elements and Use
  • Section 5: Thermal Protection
  •   5.1 Scope
  •   5.2 Definitions
  •   5.3 Condensation Control and Installation of Vapor Retarders
  •   5.4 Air Infiltration
  •   5.5 Heat Loss Certificate
  •   5.6 Comfort Cooling Certificate and Information
  • Section 6: Plumbing Systems
  •   6.1 Scope
  •   6.2 Definitions
  •   6.3 General Requirements
  •   6.4 Materials
  •   6.5 Joints and Connections
  •   6.6 Traps and Cleanouts
  •   6.7 Plumbing Fixtures
  •   6.8 Hangers and Supports
  •   6.9 Water Distribution Systems
  •   6.10 Drainage Systems
  •   6.11 Vents and Venting
  • Section 7: Heating, Cooling and Fuel-Burning Systems
  •   7.1 Scope
  •   7.2 Definitions
  •   7.3 Minimum Standards
  •   7.4 Fuel Supply Systems
  •   7.5 Gas Piping Systems
  •   7.6 Oil Piping Systems
  •   7.7 Heat Producing Appliances
  •   7.8 Exhaust Duct System and Provisions for the Clothes Dryer
  •   7.9 Appliances
  •   7.10 Venting, Ventilation and Combustion Air
  •   7.11 Instructions
  •   7.12 Marking
  •   7.13 Accessibility
  •   7.14 Appliances: Cooling
  •   7.15 Circulating Air Systems
  • Section 8: Electrical Systems
  •   8.1 Scope
  •   8.2 Definitions
  •   8.3 Power Supply
  •   8.4 Disconnecting Means and Branch-Circuit Protective Equipment
  •   8.5 Branch Circuits Required
  •   8.6 Receptacle Outlets
  •   8.7 Fixtures and Appliances
  •   8.8 Wiring Methods and Materials
  •   8.9 Grounding
  •   8.10 Outdoor Outlets, Fixtures, Air-Conditioning Equipment, Etc.
  •   8.11 Painting of Wiring
  •   8.12 Polarization
  • Section 9: Foundation
  •   9.1 Basic Requirement
  •   9.2 Chassis Removal
  •   9.3 Underfloor Ventilation
  •   9.4 Separation From Ground
  •   9.5 Site Preparation
  •   9.6 Erosion
  •   9.7 Site
  •   9.8 Vapor Retarder
  •   9.9 Connections
  •   9.10 Flood Resistance
  •   9.11 Egress Requirements
  • Section 10: Standard Set Foundation
  •   10.1 General
  •   10.2 Frost Line
  •   10.3 Footings
  •   10.4 Block Piers
  •   10.5 Block Pier Caps
  •   10.6 Block Pier Shims
  •   10.7 Block Pier Wedges
  •   10.8 Prefabricated Piers
  •   10.9 Support Requirements
  •   10.10 Marriage Line Supports
  •   10.11 Anchoring
  •   10.12 Ties
  •   10.13 Spacing
  • Section 11: Permanent Foundation
  •   11.1 Content
  •   11.2 Frost Line
  •   11.3 Footings
  •   11.4 Block Piers
  •   11.5 Block Pier Caps
  •   11.6 Block Pier Shims
  •   11.7 Block Pier Wedges
  •   11.8 Prefabricated Piers
  •   11.9 Support Requirements
  •   11.10 Perimeter Supports
  •   11.11 Marriage Line Supports
  •   11.12 Piers
  •   11.13 Location of Supports
  •   11.14 Height of Installation
  •   11.15 Permanent Foundation
  •   11.16 Foundations for Existing Home
  •   11.17 Basement Perimeter Support
  •   11.18 Grading
  •   11.19 Drainage
  •   11.20 Anchoring
  • Section 12: Accessory Buildings and Structures
  •   12.1 Underfloor Space
  •   12.2 Skirting
  •   12.3 Underfloor Ventilation
  •   12.4 Underfloor Access
  •   12.5 Foundations and Ground Level Access
  •   12.6 Carports and Awnings
  •   12.7 Porches
  •   12.8 Attached Garages
  •   12.9 Decks, Porches, Landings, Stairs, Ramps, and Guardrails
  • Section 13: Resources
Course #3404, Student Catalog
www.nachi.org/manufactured-mobile-homes-course
Student WorkTime CalculationEstimated Clock Hour Time for the Average Student
Attendance for "Seat Time" 1# of minutes of student attendance / 5026.2
Participation in Learning Activities 2# of minutes of online student participation / 503.0
Interactivity 3# of minutes of student interactivity / 500.5
Reading the Course Text 4# of words in the course / 100 words per minute / 509.3
Reading the Course Textbook 5# of words in the book / 100 words per minute / 504.6
Academic Engagement 6# of words in the course / 100 / 503.0
Direct Communication 7# of minutes of communication / 500.5
Instructional Video Learning 8# of minutes of video / 500.0
Reinforcement Q & A  9# of questions X 1.85 / 505.3
Writing Assignment of the Inspection  102.0 hours per assignment2.0
Writing Assignment of the Research  114.0 hours per assignment4.0
Academic Activities for an Inspection  126.0 hours for each inspection assignment6.0
Performing an Inspection  138.0 hours for each inspection8.0
* nachi.org/catalog-credit-hour-calculation
46.2
Total clock hours
46.0 clock hours
46.0 InterNACHI CE Hours
4.6 CEU
In keeping with InterNACHI's commitment to Continuing Education, this online training course is open and free to all members and can be taken repeatedly without limit.
Reminder to members:  InterNACHI's Code of Ethics 1.10 requires that you comply with all government rules and licensing requirements of the jurisdiction where you conduct business.  InterNACHI's courses and Standards generally exceed the Standards of Practice that you are required to abide by locally.
This course has been approved by:
Upon completion of this course and passing the 75-question final exam (drawn from a larger pool), the student can download and print their own Certificate of Completion, which is auto-generated in their own name.
The student's (InterNACHI member's) information is recorded on InterNACHI's servers for membership compliance verification, and automatically logs completion into InterNACHI's online Continuing Education log.
Non-members may view only the first page of the course.
Members will need their username and password.  If you have forgotten your password, CLICK HERE (instant response) or email fastreply@internachi.org and request it (don't forget your name).
InterNACHI... #1 in inspection education.
InterNACHI® Members:
Take the free, online How to Inspect Manufactured and Mobile Homes course now (free to InterNACHI members).
Not a member yet?
Join today for access to this and thousands of other InterNACHI® membership benefits.
Other inspection courses.
Some features that make InterNACHI's courses superior to existing continuing education options:
  • The course is free for all InterNACHI members.
  • The course is written in pure XHTML code for quick loading.  The course loads fine on old computers and loads fast, even with dial-up.
  • The course is designed using a hierarchal menu coupled with a sequential page navigation.  This provides the student with the option to easily repeat areas of weakness.
  • The course permits the student to start, stop and restart any part of the course as often as desired.
  • There are a variety of images within the course, including diagrams, illustrations and photos.
  • The illustrations can be enlarged for clearer viewing by clicking on them.
  • The text is integrated into InterNACHI's Inspector Glossary.  Rolling over blue-colored terms provides their definition.
  • The final exam uses multiple-choice questions that reference the images.
  • The course's quizzes and final exam have numerous advantages over traditional exam systems:
    1. The course, quizzes and final exam incorporate built-in intelligence which identifies and strengthens each student's unique subject weaknesses.
    2. Not only is each question weighted with regard to score, but each answer is weighted, as well as the correctness of each answer being weighted.
      1. Answers to easy questions are weighted such that the student is penalized, in terms of score, for answering incorrectly, but rewarded modestly for answering correctly.
      2. Answers to difficult questions are weighted such that the student is rewarded, in terms of score, for answering correctly, but not penalized for answering incorrectly.
      3. Answers to questions regarding basic safety, or questions every inspector should know the answer to, are weighted such that the student is severely penalized, in terms of score, for answering incorrectly.
  • Upon passing the final exam, the student can print out a Certificate of Completion which is auto-generated in their own name.
Why online inspector education is better than classroom inspector education.
Not a member yet?
Other approved and accredited inspection courses
