by Nick Gromicko, CMI®
Linoleum is a natural flooring material known for its complex, colorful patterns and widespread use during the late 19
th and early 20
th centuries. InterNACHI inspectors may encounter linoleum in older homes, although newer, green home designs have incorporated the material for its purported eco-friendly characteristics.
The major constituents of linoleum, in order of most to least composition by weight, are as follows:
Wood flour, a finely pulverized wood, is used as a filler and body component, as well as to bond pigments and ensure a smooth flooring surface. Cork flour may be mixed in.
Linseed oil is a clear to yellowish oil obtained by pressing flax seeds. When the oil is oxidized, a cement results that forms the basis of linoleum. In fact, Englishman Frederick Walton called his creation “linoleum” in the mid-1800s after the Latin words linum (flax) and oleum (oil). Linoleum’s anti-microbial qualities can be credited to linseed oil, which naturally repels germs and pests.
Limestone and other mineral fillers are used to achieve a specific density in the linoleum flooring.
Jute is a long, soft fiber used for linoleum backing, providing strength and dimensional stability. Grown in India and Bangladesh, jute is the world’s most produced vegetable fiber after cotton.
Pine rosin is used as a bonding agent to provide strength and flexibility.
Natural pigments are used to create the complex color patterns for which vintage linoleum is best-known.
Between the time of its invention in 1860 and its replacement by other floor coverings in the 1950s, linoleum was considered to be an inexpensive, durable and flexible material for high-use areas, especially kitchen floors and hallways.
In 1882, Walton developed inlaid linoleum, in which patterns extended all the way to the backing cloth. Embossed inlaid linoleum was developed in 1926. Heavier-gauge linoleum developed in the early 20th century to meet the needs of U.S. battleships and was thus known as “battleship linoleum,” but it was removed after the 1941 attack on Pearl Harbor due to flammability concerns, although it continued to be installed in public office buildings and other high-use areas.
High-quality linoleum is sufficiently flexible to be used where more rigid materials, such as ceramic tile, would crack. Its resilience and give make standing easier and reduces breakage from dropped items, while its water resistance enables easy maintenance. Linoleum can be fashioned into a variety of appearances, from replication of carpets and woods to complex floral and geometric patterns. Brightly colored game-board patterns can be made for children’s playrooms, and custom designs are limitless. Modern versions are available in sheets and tiles that may be glued directly to the subfloor, or it may be installed as floating tiles, in which the tiles or panels interlock but are not directly fastened to the subfloor, much like DIY wood flooring.
Linoleum to Vinyl, and Back Again
Linoleum’s use as an inexpensive floor covering material in homes and businesses was replaced in the 1950s by polyvinyl chloride, known as vinyl. Recently, however, linoleum’s ecological, non-allergenic and anti-microbial qualities have allowed it to make a comeback. Commonly found under i
ts trademark name Marmoleum® and manufactured by Forbo Flooring, linoleum is commonly installed in green homes and germ-sensitive environments, such as hospitals and other healthcare facilities.
Vinyl is more common in newer homes, and while it has similar durability and flexibility compared with linoleum (and is even colloquially referred to as linoleum), this synthetic product made from chlorinated petrochemicals is wholly different from its natural predecessor. Vinyl is generally considered brighter, more translucent and easier to maintain, but it’s considered less eco-friendly; phthalates and heavy metals leak from the roughly 1.5 million tons of vinyl discarded annually in the U.S., and it releases harmful dioxins when burned.
Differentiating between the two materials can be challenging, but InterNACHI inspectors and homeowners can use the following clues:
Linoleum’s patterns and colors extend down to its jute canvas backing, while vinyl patterns are stamped over a blank vinyl sheet. If years of foot traffic have worn away the surface pattern, it is not linoleum. A small razor slice can also reveal the pattern’s depth and help in identification.
Original flooring in buildings constructed before World War II cannot be vinyl, as linoleum dominated the residential flooring market before then and for some time afterward. Vinyl is more common in newer houses, especially those built in the early '70s and later.
A canvas backing will be present in linoleum, but not vinyl. You may look for a canvas backing in flooring that has been damaged, or carefully peel back a corner of the flooring in an inconspicuous area.
Inspection Tips
Inspectors may look for the following defects in linoleum:
general wear. Due to the age of the homes in which it's installed, linoleum is commonly found in some state of deterioration. Dirt in high-traffic areas and high-heeled shoes can accelerate the wearing process. Rips and tears typically result from moving heavy furniture and appliances across it. If a refrigerator or stove needs to be moved, it can be raised off the linoleum using a layer of plywood in order to minimize damage caused by dragging;
chemical changes. Linoleum is likely to become more brittle as the linseed oil continues to oxidize. Linoleum with a high proportion of wood flour or cork to linseed oil is more susceptible to deterioration in this manner;
asbestos. This carcinogenic mineral fiber was added to various products to impart strength and fire resistance before it was finally banned in the U.S. in 1969, but it still lurks in products manufactured before then. It's hard to be certain whether either linoleum or vinyl flooring contains asbestos without causing damage to the floor in order to submit a sample to a lab for testing. The process itself may disturb the asbestos fibers and cause them to become airborne. In floors that are confirmed to contain asbestos, inspect for signs of wear or damage, such as tears, abrasions or water damage that may allow the release of asbestos fibers into the air. Remedial actions may include covering the linoleum with carpet or removing it, but undamaged tile may not need any correction. An InterNACHI inspector may recommend an asbestos professional who can decide the best course of action. Read more in
InterNACHI’s article on asbestos;
off-gassing. Newly laid linoleum has a pronounced scent of linseed oil, and while this smell dissipates within several months, it may bother some people with allergies. However, harmful off-gassing may result from the glues used to bond the linoleum to its subfloor;
yellowing. Also known as “seasoning bloom” and “drying-room film,” linoleum may experience a yellowing during its manufacture process due to oxidation of the linseed oil. This yellow cast is temporary and will disappear following exposure to natural or artificial light, typically between a few hours and a few weeks after installation. In areas that are hidden from light, such as the floor surface beneath area rugs or furniture, yellowing may remain long after it has left the rest of the floor;
staining. Linoleum may be stained by rubber- or latex-backed mats due to the presence of an antioxidant. Manufacturers recommend the use of non-staining, colorfast woven rugs for use on linoleum floors;
telegraphing. Linoleum installation requires a smooth subfloor, as any unevenness will transfer to the floor surface. Telegraphing is not as much of an issue in floating tile floors, as they are not fastened directly to the subfloor;
failed adhesive. Bulging or peeling indicate that the adhesive used to bond the linoleum to the subfloor has failed and needs to be replaced. Sandbags can be placed over the tile aft
er a fresh coat of glue has been applied;
moisture intrusion from the concrete subfloor. Linoleum installed over concrete may experience moisture problems. Installers can use a moisture meter to determine whether an area is too damp to install the linoleum. Signs of moisture intrusion include sponginess, unevenness, or a separation of the linoleum from the subfloor or of the jute backing from the top layer; and
expansion and contraction of wooden subfloors. Linoleum in older homes may have buckled or cracked due to this natural process. In newer homes, installers address this problem by separating the subfloor from the linoleum by installing a layer of felt.
Maintenance Tips
Inspectors can pass on the following maintenance tips to their clients:
Install smooth plastic glides beneath furniture legs to minimize gouging of the flooring.
Clean spilled fluids quickly, as puddles will damage linoleum floors.
Use a humidifier to maintain ambient relative humidity at between 50% and 60% to prevent the flooring and its components from drying out during the heating season.
Dry maintenance, such as vacuuming and sweeping, is the safest way to keep linoleum free from dirt and grit. A damp mop can be used with a small amount of water with a neutral pH soap or a specially formulated cleaner, as long as the liquid is quickly removed. Avoid the use of chemicals that will damage the linoleum, such as bleach (which will lighten the surface color), high-alkali cleaners (which will soften the linseed oil), ammonia (which has too high a pH), and scouring powders (because they will abrade the surface of the flooring). After mopping, dry the flooring to remove excess water, as the seams of linoleum are especially susceptible to water damage. After the flooring has dried, apply a floor wax designed for linoleum floors.
In summary, linoleum is an all-natural flooring material with a long, colorful history that's installed in many older homes and businesses. It remains relatively unchanged since the 1860s but is sought after today by ecologically minded builders and homeowners. Inspectors should know how to differentiate linoleum from its alternatives and inspect for defects common to the material.
