A kerosene heater, also known as a paraffin heater, is a portable, unvented heating appliance that runs on the controlled burning of kerosene. In the U.S., it is used mainly for supplemental heating and for emergency heat during a power outage. In Japan and other countries, it is used as the primary source for home heating.
Kerosene burners operate in a manner similar to kerosene lamps: a fabric wick draws kerosene from a tank via capillary action into a burning chamber mounted above. Once lit, the wick warms nearby objects through radiation and convection. The user may control the burner’s heat by raising or lowering the wick's height inside the burning chamber. The heater is turned off by fully withdrawing the exposed wick into a cavity beneath the burner.
Kerosene heaters are favored for their portability, efficiency and lack of reliance on electricity. They also lack a pressure-fed fuel system, which is a significant safety advantage over standard heating systems. However, the following problems plague kerosene heaters:
The aforementioned safety concerns can be addressed by inspecting for the presence of the following safety design features:
Safe-Use Practices
