Here's a picture of step flashing being inspected at the InterNACHI® House of Horrors®.
Here's a picture of kickout flashing being installed at the InterNACHI® House of Horrors®.
Flashing Required by IRC
Flashing at wall and roof intersections is required in the International Residential Code (IRC). Please refer to 2021 IRC Section R704.3. The IRC requires that flashing should be installed where there are areas subject to moisture intrusion. Roof and wall intersections create significant challenges for builders and contractors, particularly where the end of a rain gutter intersects with exterior wall covering. This location on the exterior envelope may provide an open route for water or moisture to enter the building.
Kickout Flashing
A kickout flashing is a special type of flashing installed at the edge of a roof where the eaves meet a wall. A common example is where the eaves of a garage roof meet the wall of a two-story home. Another example is where the end of a rain gutter meets the side of a stucco-covered chimney stack. The kickout flashing should extend out from the wall (or side of the chimney stack), protrude away from the siding, and direct roof runoff away from the wall.
Here is a picture of an area where kickout flashing should be installed where the roof and wall intersect, and the roof gutter ends, but it is not.
The term "kickout flashing" has not been used in the IRC (as of 2021). The 2012 IRC, Section R903.2.1, says, "Flashings shall be installed at wall and roof intersections, wherever there is a change in roof slope or direction and around roof openings. A flashing shall be installed to divert the water away from where the eave of a sloped roof intersects a vertical sidewall." Unfortunately, "kickout" is not used in this section, and there is no illustration of the flashing either.
Here is an inspection picture of water stains down a chimney stack below the missing kickout flashing at the area where the gutter end intersects with the stucco exterior wall of the stack.
Deluging rains can pour thousands of gallons of water onto a home’s roof in a single storm. In multi-level house designs where roofs intersect walls, much of this water is channeled along the wall to a gutter. If sidewall flashing is lacking or inadequate, water runoff can get inside the wall and cause serious damage. In big storm events, rainwater can often overflow the gutter and stream down the walls.
Diverters are sometimes fashioned on-site in an attempt to direct this water into the gutters. If undersized, these diverters are not very helpful. If not properly integrated with the existing housewrap and cladding, they can do more harm than good by allowing water inside the wall cavities. The result can be significant damage to wall sheathing, framing, and insulation, as well as mold inside the wall cavities. While older wood siding would show evidence of this water intrusion by peeling paint, new wall claddings, such as fiber cement, vinyl siding, stucco, and brick veneer, can mask the evidence for years.
Here's an inspection picture of a missing kickout flashing at a chimney stack.
Here is an illustration of a typical step and kickout flashing detail provided by InterNACHI's Inspection Image Gallery.
Here is a step-by-step procedure on how sidewall step and kickout diverter flashing should be installed on houses with rigid foam insulation. Knowing how components are properly installed can help home inspectors conduct better inspections.
To be effective, kickout flashing has to be layered with the framing, weather-resistive barrier (WRB), trim, roofing, and siding properly so that it prevents water from entering the wall assembly and diverts the water away. The following pictures are from the U.S. Department of Energy’s Building America Best Practices Series, Volume 11.
The image above shows that the drip edge and roof underlayment should be applied over the roof deck and continue lapping up the sidewall and over the water-resistive barrier (in this case, rigid foam insulation) a minimum of 7 inches.
From the image above, the shingle starter strip should be installed at the roof eave in accordance with the roofing manufacturer’s instructions.
A seamless, one-piece, non-corrosive kickout diverter should be positioned and installed as the first piece of step flashing. The kickout diverter should be positioned on the roof plane where the starter trough stops at the shingle starter strip. The diverter must be flat on the roof and flush to the sidewall. The diverter should be fastened and sealed to the roof deck and starter strip.
Sidewall Step and Kickout Diverter Flashing Installation with Wood Sheathing
Here is a step-by-step procedure on how sidewall step and kickout diverter flashing should be installed on houses with housewrap over oriented strand board (OSB) or plywood sheathing.
Summary
Where roofs intersect walls is a critical point for flashing to be installed in order to prevent water leaks and damage. While wood siding may show evidence of this water intrusion, with peeling paint or staining, some wall claddings, such as fiber cement, vinyl siding, and brick veneer, can mask the evidence for years. Flashing and diverters must be correctly integrated with housewrap, cladding, and gutters to prevent water damage. Home inspectors may check for step flashing and roof-wall water deflectors that help drain water away from high-risk corners where walls meet roofs.
Take InterNACHI's free, online "How to Perform Roof Inspections Course."
