Blocking can help correct areas with twisted framing, as well as provide surface for the panels.
Panels
Plywood panels should be laid with the face grain perpendicular to the rafter boards. The panels should be installed over two or more spans, with the long dimension or strength axis oriented across the rafter boards or truss cords.
In the above image, the contractor is laying down the plywood panel with the face grain perpendicular to the trusses. Staggering panels by at least two supports is recommended.
During the installation of OSB, the rough surface side should be facing up. This rough side is a screened or skid-resistant coated side.
Panel Ends
The panels should be spaced 1/8-inch apart at the ends and edges.
The panel ends must be joined over a support. The panel joints should rest along the center line of the support framing with at least 1/2-inch of bearing. Tongue-and-groove edges or solid blocking may provide support at the edges. Panel edge clips may be installed to provide additional support along the edges. Clips may actually be required. One clip is usually installed in each span. Blocking, tongue-and-groove edges, and/or supports, such as panel clips, may provide adequate support for unsupported edges.
Fastening
Wood structural panels should be attached to the framing in accordance with the following table.
Fastening Wood Structural Panels to Framing |
Panel Thickness
| Fastener Type
| Fastener Spacing on Edges
| Fastener Spacing at Intermediate Supports |
3/8-inch to 1/2-inch | 8 d common nail (2-1/2 inches) | 6 inches apart | 12 inches apart |
19/32-inch to 1 inch | 8 d common nail (2-1/2 inches) | 6 inches apart | 12 inches apart |
For common installations, the panels are fastened with 8 d common or deformed shank
nails. Fastening schedules have certain requirements for high-wind zone
locations and where the roof is specially engineered.
For common installations, fasteners are spaced on the edges 6 inches apart, and 12 inches apart along the supports. There should be at least 3/8-inch of space between the fastener and the panel edge.
In areas where the wind speed is greater than 130 mph, nails for attaching the roof sheathing to intermediate supports should be spaced 6 inches on center for at least the first 48 inches from the ridges, eaves, and gable end walls. The fasteners should be spaced only 4 inches apart on the panel edge at the gable end wall framing.
Fasteners should be driven flush with the panel surface.
Summary
These tips are useful for home inspectors who perform New Construction Inspections, as well as for inspecting homes that undergo roof repair or replacement due to age or heavy weather events.
