House-raising is a hefty undertaking, as the utilities must be disconnected and reconnected, truckloads of dirt must be excavated, and concrete walls need to be poured. The actual lifting of the structure involves long, steel I-beams and hydraulic jacks. It’s possible to lift a house rapidly, although, in certain situations, such as to avoid damage to drywall, the building might be lifted as little as 1/8-inch per day. A homeowner can expect to pay up to $10,000 to raise their 1,200-square-foot house by a few feet, and older homes may be more difficult to lift, as they typically weigh more because of their plaster construction and sturdier wood. After being raised, the building is held in place by support cribs for however long is necessary to complete the project.
The idea of hiring workers to crawl beneath a precariously perched 40- to 80-ton structure may conjure up various nightmare scenarios. And the dangers to life and property are real, which is why house-raising companies typically carry insurance to cover an unlikely, yet tragic and costly, collapse. Such an incident happened in 1994, when contractors in Canada had to scramble for their lives when inadequately nailed sheathing caused the house they were working under to slide from its foundation.
Additional Considerations for the Homeowner
