Ever wonder about your house number? Often, the previous owner installed the number and the new owner never had to think about it, leaving them clueless as to why it was placed where it is or why a particular color or size was chosen. These numbers are more important than you probably realize, and a lot of thought goes into making sure they are visible.
Consider the following recommendations:
Keep in mind that you may need to make adjustments.
Even if your house number is currently adequate, InterNACHI believes that it might need adjustment in the future. The following are common reasons why you may need to adjust your number in the future:
Maintain your house numbers, along with the rest of your home's exterior.
