"Green roofs" are areas of roofs of residential, commercial and industrial buildings that are utilized as space for growing vegetation. They are actually built onto the roof's
surface in contrast to a rooftop container-garden or rooftop garden, in which plants are kept in individual containers. Green roofs capture precipitation, use it for plant growth, and then return it to the atmosphere through evapotranspiration, as opposed to typical bare roofs, which repel moisture and heat. The use of the term "green" refers to the roof's association with the environmental movement, and does not necessarily refer to the color of vegetation being grown. Green roofs can range in complexity from a basic layer of soil to intricate, irrigated landscaped gardens frequented by the public for pleasure.
There are two basic types of green roofs: intensive and extensive. The term "intensive" is used because these types of systems generally require a great deal of care and maintenance. Intensive green roofs integrate a large variety of different types of plants, such as vegetables, flowers, trees and shrubs. They require deeper soil and are heavier than extensive designs, and are intended for use by the public. Extensive rooftop gardens are less elaborate, featuring fewer plant species and requiring less maintenance.
It is possible to purchase green roofs as complete systems. However, many systems are constructed on site using a layering process. Waterproofing material is first laid directly on top of the roof. Next is a layer that inhibits root growth and acts as a barrier between the garden and the roof itself. In some cases, this is the most expensive component of the system. The root barrier may be achieved by the use of a copper laminate or other chemical additives. An insulation layer may be laid next, followed by a drainage layer. These are followed by the growing substrate (usually soil), which may be comprised of organic and/or inorganic matter. Vegetation is then planted on top. A protective cover may be added over top of newly developing plants to ward against excess wind and to encourage root establishment. Some systems implement rainwater harvesting as a means to irrigate vegetation during periods without rainfall. Others use municipal water supplies. Drip-irrigation may be utilized, especially in larger systems. Green roofs installed onto pitched roofs tend to follow a simpler design that requires less waterproofing and drainage.
In summary, green roofs are an economical and environmentally friendly way to take advantage of unused roof space. Those considering installing them should enlist the aid of qualified landscape engineers for design options and maintenance requirements, as well as structural engineers familiar with local code requirements.
