InterNACHI finds that green lumber is more commonly used in arid regions of the United States, such as Arizona and parts of California, because the wood will dry more quickly. Damper regions often require kiln-dried wood, which must have a moisture content of 19% or less. The additional expense of kiln-dried wood is the reason it is used in only a small portion of construction.
Freshly cut wood will gradually lose moisture until it reaches equilibrium with its surroundings, which is referred to as its “equilibrium moisture content” (EMC). As it dries, the wood will shrink in size. Wood will continue to lose moisture until it reaches EMC, at which point it’s said to have reached its “in-service condition.”
The water that fills wood cells is known as “free water,” which accounts for most of the water weight of a tree. Cell walls also contain water, which is known as “bound water.” The weight of the water can account for more than half the mass of a tree in some species when it is cut down. Ideally, the lapse between the time the tree is first cut until the tree’s wood is used in construction will allow for most or all of the free water to evaporate, but this does not always happen. Shortly after wood is processed in mills, it is bundled and wrapped in plastic, which retards evaporation. The wood has little chance to dry until the bundle is unwrapped and the framing process begins at the construction site.
Why is green lumber used?
