A French drain is a common means of diverting water from one location on a property to another in order to divert excess rainwater or to dry up soil that is excessively waterlogged, such as land that is located near wetlands. Inspecting French drains is not within the scope of InterNACHI’s Residential Standards of Practice because they are typically located underground and not visible. However, inspectors may want to know more about this method of preventing flooding on a property because French drains may fail and subsequently cause visible signs of flooding at the exterior of a home’s property and potential moisture intrusion problems that affect the home itself.
What is a French Drain?
Advantages of French Drains
A French drain may be installed if there is a gravel pathway at the surface of a ditch. Inspectors may want to check:
