Historic buildings are often more energy-efficient than modern construction. In fact, studies have shown that buildings constructed before 1940 require less energy consumption for heating and cooling than houses built during the subsequent 35 years. Before electricity was available, homes capitalized on natural sources of lighting, heating and ventilation because the house itself – not electric lights and heaters – was all that protected occupants from the elements.
Some specific elements of older buildings that contribute to their excellent energy efficiency are as follows:
windows were only installed where they could effectively allow for lighting and ventilation. Modern architecture, by contrast, relies on more windows than are necessary as a stylistic measure, with a reduced R-value as an unfortunate side effect.
Retrofit dangers to avoid in historic buildings:
removing historic windows and other components, adding aluminum siding, or installing dropped ceilings in interior spaces.
Retrofits in Historic Buildings
The following retrofits are often used in historic buildings to make them more energy-efficient:
