Alternating Current and Direct Current
Which one is dangerous: voltage or current?
A common adage goes, “It's not voltage that kills, it's current!" This is essentially correct. However, if voltage presented no danger, no one would ever print and display signs saying: "DANGER -- HIGH VOLTAGE!" It is electric current that burns tissue, freezes muscles, and fibrillates hearts. However, electric current doesn't just happen on its own -- there must be voltage available to motivate electrons to flow through a victim.
High voltage is not inherently dangerous. Track your feet across carpet on a dry winter day and you will charge your body to several thousand volts. If you then touch metal, the resulting static discharge will have a voltage many times greater than a typical home’s electrical system, yet you will be perfectly safe because the current is not sustained.
A person's body presents resistance to current. The following two variables partly determine whether an electric shock will cause bodily harm:
In summary, electrical terms such as volts, amps, ohms and watts describe distinct electrical phenomenon, although they are dependent on one another.
