Balconies, decks and porches that are accessible from inside the dwelling unit shall have at least one receptacle outlet installed within the perimeter of the balcony, deck or porch. The receptacle shall not be located more than 6½ feet (2m) above the balcony, deck or porch surface.
Balconies, decks or porches with a usable area of less than 20 square feet (1.86 m2)
are not required to have a receptacle installed.
- The 2008 requirement is a supplement, not a replacement, to the requirements in effect in 2005. The 2008 NEC lists them both.
- The newer requirement does not necessarily require installation of additional receptacles in new construction. Depending on the location of the balcony, deck or porch, a single receptacle may comply with both requirements.
- InterNACHI inspectors should not call out the lack of exterior receptacles as a defect in houses that were built before the code was enacted. Inspectors can recommend that receptacles be installed as a safety measure.
Extension cords are likely to be used to run appliances on large balconies, decks and porches (greater than 20 feet square) if receptacles are not installed at these locations. Extension cords can be dangerous, especially if used outdoors and in wet conditions. The dangers associated with extension cords are…
GFCI protection isn’t required for a fixed electric receptacle supplied by a dedicated branch circuit, if the receptacle isn’t readily accessible and the equipment or receptacle has ground-fault protection of equipment.
