A baghouse, or fabric collector, is the generic name for an air pollution-control device designed to filter dust and other fine particles from contaminated air in commercial and industrial facilities. Baghouses provide clean air for employees and customers, protect the environment of nearby equipment, and lessen the plant’s contribution to outdoor air pollution.
Baghouses control the emission of air pollutants in many industries, such as steel and foundry operations, power plants, chemical production, food manufacturing, and pharmaceutical plants. They came into use in the 1970s upon the development of fabrics that could withstand the high temperatures of dusty industrial gases. Collecting this dust is important because it can be harmful if inhaled, and it may even fuel a deadly explosion. (Read
InterNACHI’s article on dust inspection to find out more about the potential hazards of dust.) Other commercial and industrial air-filtration devices include electrostatic precipitators, unit collectors, wet scrubbers and inertial separators.
- Dust-laden air is pulled through ductwork where it enters the hopper, which is a large funnel-shaped container.
- The air is then drawn through a collection of cylindrical bags and expelled to the outdoors through an exhaust stack.
Dust and other particles too large to pass through the bags will accumulate on the bags' surfaces and form a layer known as a dust cake, which thickens and slows the rate that gas can enter the bags. This resistance to air flow, known as pressure drop, will eventually prevent any air from entering the bags, at which point the dust cake must be removed before normal operation can continue. Dust-cake removal processes can be divided into distinct methods, which are, in turn, used to categorize the types of baghouses. The four most common designs include:
Inspection and repair of baghouse components are required to ensure that the system functions as designed. Inspection procedures can differ considerably based on the design of the baghouse, but the following defects are harmful to most designs:
Baghouse efficiency may also be affected adversely by a number of outside variables, such as:
In summary, baghouses are filtration devices used to enhance air quality in commercial facilities and industrial plants. Although their inspection is beyond the scope of InterNACHI's Commercial Standards of Practice, commercial property inspectors who understand how they work are in a better position to spot obvious problems or defects and can alert their clients so that they can take appropriate action.
