Mastering Roof Inspections: Asphalt Composition Shingles, Part 6
TYPES of ASPHALT SHINGLES
During inspections of roofs with asphalt shingles, you may see one of four basic types:  three-tab, laminated, interlocking, or single-piece shingles.
There are variations of these basic types that affect their appearance, weight, performance and durability.
Three-Tab Shingles
This is a three-tab (or 3-tab) shingle. It’s a type of strip shingle.
Its main identifying feature is two notches, called cutouts, which separate the lower part of the shingle into three tabs, as you can see here.  A three-tab shingle is a single layer thick, usually 12 inches wide and 36 inches long. Metric shingles are a little larger but are less common in the U.S.
Three-tab shingles typically have warranties in the 20- to 30-year range, weigh 200 to 250 pounds per square, and are designed to survive winds of up to 60 miles per hour.
Laminated or Architectural/Dimensional Shingles
This is an example of a laminated shingle, also called an “architectural” or “dimensional” shingle. Both laminated and 3-tab shingles are considered to be strip shingles.
Laminated shingles consist of two or more shingle layers bonded together. The uppermost layers are smaller and cut into shapes.
This gives shingles a more three-dimensional appearance and makes them more interesting to look at. They’re sometimes designed to mimic wood shakes.
Laminated shingles typically come in metric sizes, measuring about 39x13 inches.
Laminated shingles with 30- to 50-year warranties typically weigh 250 to 300 pounds per square, and are designed with a maximum wind resistance of 70 to 110 miles per hour.
High-Quality Laminated Shingles
Here’s an example of a high-quality laminated shingle. Some of the more expensive laminated shingles may have up to five layers and weigh close to 500 pounds per square. These shingles may be designed to withstand winds of up to 130 miles per hour.
Interlocking Shingles
These are examples of the most common type of interlocking shingle. They’re called T-locks. Although they’re not installed anymore, many homes were roofed with T-locks which are still in place, and many of them are still in good condition.
T-lock shingles have no adhesive strip, so they rely on the interlocking profile and fasteners to hold them in place.
The manufacture of T-locks ended about 2006.
CALCULATING  and PACKAGING SHINGLES
The amount of asphalt shingles required to cover a roof is calculated by the square.  A square is an area 10x10 feet.  Shingles are sold by the bundle, and a square may contain from three to six bundles, depending on the shingle design and exposure.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
