Mastering Roof Inspections: Asphalt Composition Shingles, Part 22
FLASHING, Part 6
Mechanical Attachment Points
Various types of mechanical equipment installed on roofs penetrate the shingles. Some examples include the following.
Braces for chimneys, flues and electrical masts penetrate shingle roofs.
Don’t expect to see flashing. Braces are usually bolted to the roof framing, and you may or may not see sealant.
Sometimes, you will see flashing for air-conditioning equipment.
Sometimes, however, you will not, depending on the installation quality and type.
Photovoltaic panels should be installed using flashing components called “standoffs.”
Standoffs allow air to circulate beneath the panels, helping to keep them cool.
Solar thermal panels, which provide hot water heated by the sun, probably won’t be flashed if the system is older.
Newer systems are typically installed using standoffs.
Satellite dishes typically bolt through roof brackets and won’t even have sealant applied. This is standard practice and isn’t usually a problem.
You’ll see a variety of attachments for patio covers. Generally, the older the work, the less likely it is to have flashing installed.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
