Kickout Flashing
Where a wall extends past a roof eave, sidewall flashing stops at the edge of the eave, since this is where the sidewall condition ends. At the lower roof edge, sidewall flashing should extend out from the wall at least a couple of inches and be bent to an angle. This is called "kickout" flashing.
Except for a few manufacturers whose requirements you won’t know about, there are no minimum size requirements.
This particular kickout is bigger than most you’ll see. Usually, the kickout is cut from a piece of the step-flashing.
This detail is kickout flashing, and its purpose is to prevent runoff from entering behind the exterior wall-covering where the flashing ends.
Kickout flashing is required regardless of the type of roof-covering material or exterior wall covering, with the exception of brick and concrete block, since sidewall flashing doesn’t penetrate the wall with those types of coverings.
Water cascading down the sidewall joint needs to be diverted to the exterior of the siding when it reaches the edge of the roof. This kickout needs to have a sealant applied to make the kickout waterproof.
Here are some examples showing kickout flashing that is missing.
A kickout is easy to fabricate on site. A piece of step-flashing is cut partially through one flange, and the corner is clipped off.
Then, it’s bent to shape and installed.
Changes in Roof Slope or Direction
As already mentioned, the IRC calls for flashing to be installed at areas in which the roof changes slope or direction. Here are examples of some of these areas.
Valleys
The ways that valleys are flashed often vary according to the method used for installing shingles in the valley.
Hips
Learn how to master a roof inspection from beginning to end by reading the entire InterNACHI series: Mastering Roof Inspections.
Take InterNACHI’s free, online Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
