Mastering Roof Inspections: Asphalt Composition Shingles, Part 17
FLASHING, Part 1
IRC Requirements
The IRC doesn’t give specific flashing details which have to be followed.  It says that flashing has to be corrosion-resistant, and installed in a manner that prevents moisture entry.
Multiple methods can be used to install flashing correctly, so you won’t be looking for only one method and calling everything else a defect. You'll be checking to see whether flashing was installed in a manner that will prevent moisture entry, and you’ll be looking for corrosion.
The IRC requires roof flashing to be installed in the following locations:
  • headwall and sidewall areas (anywhere a roof meets a wall);
  • changes in roof slope or direction, which includes changes in pitch, and places where roofs intersect to form hips or valleys; and
  • around roof penetrations.  "Penetrations” include anything that penetrates the roof, such as chimneys, vents and skylights.
Let's take a look at some of these areas in detail.
ROOF-WALL INTERSECTIONS
Places where roofs and walls intersect are called headwalls and sidewalls.
Headwall Flashing
A headwall is a junction where the top of a sloped roof meets a wall.
This image shows proper flashing at a headwall condition.
Headwall flashing should extend up behind the exterior wall covering and down over the shingles, as you see here. This image shows counter-flashing installed behind the siding.
Sometimes, the exterior wall-covering material serves as the counter-flashing, and this is acceptable.
Flashing should always overlap the roof-covering material.  However, for aesthetic reasons, on asphalt shingle roofs, the headwall flashing flange that extends down over the shingles is often covered with a course of shingle tabs.
Sometimes, it can be difficult to tell.
Don’t mistake this condition for headwall flashing routed beneath the shingles and call it a defect.
Here, you see new construction where headwall flashing was installed behind the siding and is waiting for shingles to be installed. The flange that rests on the underlayment is only tacked. Shingle installers will pull the tacked nails and slide the shingles beneath the flashing.
Building codes give no minimum dimensions for headwall flashing that apply to every manufacturer and jurisdiction, so your concern is to check to see whether headwall flashing was installed in a manner that will keep the water out.  Common flange sizes are 4x5 inches.
Headwall flashing typically comes bent to 120 degrees.  It can be easily flattened for roofs with shallower pitches.
Occasionally, you’ll see a roof that has had 90-degree sidewall flashing substituted for 120-degree headwall flashing.  The 90-degree sidewall flashing doesn’t bend well to accommodate roofs with steeper pitches. Over time, thermal expansion and contraction will loosen the nails, and you’ll likely see gaps open beneath the flashing. Wind-driven rain can enter at these gaps, causing roof leaks.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
