Mastering Roof Inspections: Asphalt Composition Shingle, Part 4
Back-Surfacing
“Back-surfacing” is a coat of finely pulverized mineral, such as talc, sand or limestone.
Back-surfacing is applied to the backs of shingles to help keep them from sticking to manufacturing equipment during production and from sticking to each other, once they’re stacked. If you rub your finger on the back of the mat, you can feel the gritty back-surfacing.
Granules
Granules embedded into the weather surfaces of shingles are made from fine-grain, opaque, crushed rock particles. Opaque granules don’t allow light to pass through.
After being run through a screen to help ensure uniformity of size, they’re covered with a colored ceramic coating.
The uniformity with which granules are applied can affect the way they look on the roof.
Granules have four main purposes:
1.  They reflect sunlight, which helps keep the roof cool. Keeping the roof cool will help slow the loss of volatiles which keep shingles flexible, durable and waterproof. Reflecting sunlight also helps protect the asphalt from the damaging ultraviolet or UV radiation in sunlight.
High-tech granule coatings originally developed by the military to make tanks less visible to radar are now being used to coat shingle granules. These coatings reflect up to three times the amount of light reflected by conventional granules. This can help keep roofs cooler in hot climates, which extends the service life of the shingles and reduces home cooling costs. In colder climates, it may also interfere with the ability of the adhesive strip to fully bond.
2.  Granules add weight, which helps the adhesive strip to bond well and improves wind-resistance.
3.  They also make shingles more durable by protecting them from weathering and abrasion.
4.  Lastly, granules improve shingle fire-resistance.
 InspectorSeek.com
Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
