Access by Window
Once you’ve decided to walk a roof, you'll have to decide how best to gain access. One way is by climbing out a window.
This can be the safest method, since it eliminates ladder-climbing, but you’ll need to be careful not to damage screens, walls or window trim.
You may also be able to access the roof from a deck or balcony, either by climbing over the rail onto an adjacent roof slope or by setting up a ladder.
LADDERS, Part 1
The typical method for accessing roofs is by a ladder resting on the ground and leaning against the edge of the roof. Finding a method for stabilizing ladders is highly advisable, since they become more unstable as you climb. One of the most common and serious fall hazards you’ll face is stepping from the roof onto the ladder. Standing your ladder at an inside corner or against a wall will help provide a margin of safety.
Since it’s easy to scratch gutters, it’s a good idea to place your ladder in an inconspicuous location, if possible, such as at the side of the home, rather than at the front or the back. Your ladder should rest against an eave, and not a rake. If you have to choose between risking a gutter scratch or safety, choose safety.
Choosing a Ladder
In accessing roofs, the most important piece of equipment is your ladder. Most of the time, you’ll be accessing the roof with your ladder, and the emphasis here is on “your” ladder. Never use a ladder you find on-site. You need to be familiar with the operation of the ladder you use to be sure that it’s in good condition. Never use a damaged ladder.
We’ll look at the different kinds of ladders and the situations in which they’re used, but a few rules are true no matter what ladder you use.
Read the label. You’ll be looking first at the load capacity. Ladders are generally rated as follows:
Some companies manufacture ladders rated for more weight than a Type I. Specialty ladders are available that are rated for up to 375 pounds.
As an inspector, your ladders are tools that you’ll use a lot. Low-quality ladders may be less expensive, but they’re not as sturdy, durable and safe as high-quality ladders. Always buy the best ladders you can afford.
You’ll be safer if you use ladders appropriate for each use.
Extension ladders are better for accessing roofs. Step-ladders are better for accessing attic hatches.
Safety Rules for All Ladders
These safety rules apply to all types of ladders:
Learn how to master a roof inspection from beginning to end by reading the entire InterNACHI series: Mastering Roof Inspections.
Take InterNACHI’s free, online Roofing Inspection Course
Roofing Underlayment Types
Fall-Arrest Systems
Roofing (consumer-targeted)
