InterNACHI SOP 3D Focus Edition
Enter coupon code nachi2009 for a $100.00 discount
This InterNACHI Focus edition is tailored towards any InterNACHI Member (International Association of Certified Home Inspectors) or Inspector that adheres to the InterNACHI Standards of Practice (SoP's). The 3D InterNACHI reporting system provides a professional, customizable and finished report that follows the InterNACHI SoP's. The 3D InterNACHI form includes a detailed collection of comments for most conditions you could encounter. Combining the 3D Inspection Software and the California 3D InterNACHI Form set you will have a computer generated report that helps you make sure your inspection and report meets the InterNACHI (International Association of Certified Home Inspectors) STANDARDS OF PRACTICE.
Printed in part of the report are excerpts of the InterNACHI SoP's, each section includes the areas to be reported on per the SoP's. The reported areas with findings follow. Then at the end of each section are the areas not reported on per the InterNACHI SoP's. All line items are sequentially numbered for easy identification purposes by all parties involved. The section break down and numbering eliminate the fumbling around to find certain comments as all of the electrical comments are in the electrical section, as the plumbing comments are in the plumbing section etc. The computerized report, has attached documents including two styles of cover pages and a fully customizable Summary page.
Included are thousands of 'picks' responses for the hundreds of conditions and items you inspect and report on. Each comment is customizable to fit the specific needs at the time of inspection.
Straight out of the box California 3D InterNACHI SoP is set up for most any size residential structure complete with the following:
  • Areas to report on Four (4) Water heaters
  • Areas to report on Four (4) Electrical Sub Panels
  • Areas to report on Four (4) Heating and Air Conditioning System
  • Areas to report on Four (4) Fireplaces
  • All areas are also easily expandable through Custom Form Studio (which is included) to add more for the really large residences.
Photos when needed can be added to any line in the report. You can add 1-4 photos and customize the size right in the program. Editing of photos includes the ability to add arrows, circles, rectangles, fill circle, fill rectangles, text comments. You can also zoom areas of the photo, adjust the brightness, crop, rotate and flip photos to get them how you like before insertion into the report.
Additional and most importantly the California 3D form set is fully customizable, allowing you to edit or add comments. You can also add or duplicate headings and systems any way you want to meet your inspection needs. The attached Documents in the Action pane are also fully customizable to meet your needs and requirements.
To learn more and to purchase the complete 3D InterNACHI Focus version please proceed to:
Existing 3D users who wish to just purchase the InterNACHI Form sets click on the link below to contact me and the same $100.00 discount will apply.
Thanks,
Chuck Lambert
714-915-2443
