by Nick Gromicko, CMI®, Thomas Zachar and Kate Tarasenko
It is estimated that approximately 2,400 children suffer from electrical shock and burns in the home each year when they force foreign objects into unprotected electrical outlets. Installing tamper-resistant receptacles (TRRs), also called tamper-resistant outlets, are one way to safeguard young ones in the home to prevent serious injury.
Other forms of outlet protection are available, such as plastic coverings, but they can be easily removed by children and are therefore not labeled as tamper-resistant. A TRR is a type of electrical outlet that requires double-prong entry in order for a plug to enter. These devices were designed to prevent the accidental insertion of hairpins, keys, knives, paper clips, nails, screws, and other small objects, which can pose an electrical shock hazard. Home inspectors and homeowners can identify these outlets by looking for the letters “TR” or the words “tamper-resistant” imprinted on the receptacle’s surface, which means that they're tamper-resistant and have been tested to sustain periods of extended use and some forms of physical damage.
How TRRs Work
Inside the TRR outlet is a spring-loaded shutter mechanism that blocks single-prong entry. When using a grounded or ungrounded plug, (2- or 3-prong), the blades of the plug press both shutters against the spring. This combined force slides the shutters and opens the slots for electrical contact. When the plug is removed, the shutters close and re-cover the openings.
With a TRR, be sure that the
stems of the plug are not bent and that the plug is inserted as straight as
possible. Slight maneuvering may be required, depending on the quality of
the outlet. If there is an issue, the TRR may be defective and should be
replaced.
The Code
Here is what the 2011 NEC says about TRRs in dwelling units, along with general installation requirements:
406.12 Tamper-Resistant Receptacles in Dwelling Units. All non-locking type 15A and 20A, 125V receptacles in the following areas of a dwelling unit [210.52] must be listed as tamper-resistant.
Ex.: Receptacles in the following locations aren’t required to be tamper-resistant:
(1) Receptacles located more than 5½ feet above the floor.
(2) Receptacles that are part of a luminaire or appliance.
(3) A receptacle located within dedicated space for an appliance that, in normal use, isn’t easily moved from one place to another.
(4) Non-grounding receptacles used for replacements as permitted in 406.4(D)(2)(a).
For guest rooms and guest suites, the 2011 NEC adds:
406.13 Tamper-Resistant Receptacles in Guest Rooms and Guest Suites. Non-locking-type 15A and 20A, 125V receptacles in guest rooms and guest suites must be listed as tamper-resistant.
And in childcare facilities:
406.14 Tamper-Resistant Receptacles in Child Care Facilities. Non-locking-type 15A and 20A, 125V receptacles in child care facilities must be listed as tamper-resistant.
Here are the installations requirements, per the NEC:
406.4 General Installation Requirements.
(D) Receptacle Replacement.
(4) Arc-Fault Circuit Interrupters. Effective Jan. 1, 2014, where a receptacle outlet is supplied by a branch circuit that requires arc-fault circuit-interrupter protection [210.12(A)], a replacement receptacle at this outlet must be one of the following.
(1) A listed (receptacle) outlet branch-circuit type arc-fault circuit-interrupter receptacle.
(2) A receptacle protected by a listed (receptacle) outlet branch-circuit type arc-fault circuit-interrupter type receptacle.
(3) A receptacle protected by a listed combination type arc-fault circuit interrupter type circuit breaker.
(5) Tamper-Resistant Receptacles. Listed tamper-resistant receptacles must be provided where replacements are made at receptacle outlets that are required to be tamper-resistant elsewhere in this Code.
(6) Weather-Resistant Receptacles. Weather-resistant receptacles must be provided where replacements are made at receptacle outlets that are required to be so protected elsewhere in the Code.
In summary, tamper-resistant receptacles are among the best ways to prevent electrical injuries from outlets. Be sure to have your InterNACHI-Certified Professional Inspector® visit your home to perform an Annual Home Maintenance Inspection so that s/he can check electrical and other potential safety issues, especially if you have young children.
