Choosing a Manufactured Home
Manufactured homes no longer have to be the simple, rectangular, boxy trailer
homes of the past. Depending on the size of your homesite, you can choose from
single-section or multi-section designs. Homes range in size from 900 to 2,500
square feet and can be customized to meet your needs and preferences.
What features are available?
The interior design of your home can include many of the custom features available
in a conventional home. Because most manufacturers use computer-assisted design,
you'll have flexibility in choosing variations to floor plans and decor. You can
also choose from a variety of exterior designs, depending on your taste and budget.
Exterior siding comes in an array of colors and materials including metal, vinyl,
wood and cementicious sidings which are virtually fireproof. Awnings, enclosures
around the crawl space, patio covers, decks and steps also are available.
How much can I expect to pay for a home?
Depending on the size, floor plans and any custom features, a new home can cost
anywhere from $15,000 to more than $100,000. This price doesn't include land.
What financing options are available?
Your retailer usually can provide information about financing. You can also check
with lenders in your area. Just as there are choices when you buy a site-built
home, there are a variety of financing options when you buy a manufactured home.
Down payments and loan terms are similar to conventional loans- 5 to 10 percent
of the manufactured home's sales price, and loan terms from 15 to 30 years. Most
lenders offer fixed and variable rate loans and most have programs that allow
you to "buy the rate down." If you own or plan to purchase the land where you
will place your home, traditional mortgage financing can often be arranged.
What other costs can I expect to pay?
While your mortgage payment may be your biggest expense, you'll have other regular
and periodic payments which will vary with your circumstances. Regular expenses
may include utilities, property taxes, land rental fees, insurance, routine maintenance,
and other service fees such as water and sewer. Today's manufactured homes are
built to meet new national energy standards set by HUD. The energy-conserving
features found in manufactured homes help reduce monthly energy costs.
How much maintenance will my home need?
Your homeowner's manual outlines maintenance requirements and it's important
that you follow them. Failure to follow them could void your warranty as well
as erode the value and shorten the lifespan of your home.
What warranty coverage is offered on the home, its transportation, and installation?
All manufacturers offer a written warranty which should cover…
- structural workmanship;
- factory-installed plumbing, heating and electrical systems; and
- factory-installed appliances, which also may be covered by separate warranty
- appliance manufacturer warranties.
There are important differences among warranties. For example, manufacturer warranties
usually do not cover installation (also called "set-up") and transportation of
the home, although you may be able to get this coverage through the retailer or
installation contractor. Although you may never need such warranty services, it's
a good idea to check the coverage on any warranties offered before you buy.
As an InterNACHI-certified home inspector I know where to look for defective
work. Whether you’re buying an existing home or considering a new home, allow
me to use my special knowledge to help protect you by finding defects while the
home is still under warranty and before they cause damage or injury to you or
your family.
Where can I locate my home?
Many homes are placed on privately owned property. If this option appeals to
you, find out about zoning laws, restrictive covenants, and utility connections.
Your retailer can give you more information. Another option is to place your home
in a land-lease community specifically designed for manufactured homes. Here,
you own the home but lease the land. Placing your home in a land-lease community
involves fewer siting considerations such as utility connections. A third option
is buying the home and land together in a planned subdivision where siting issues
are handled by the developer.
May I move my home?
Yes, but it's not a common scenario. The transportation of a home can place considerable
stress on its structure and contents. Nevertheless, if you do plan to move your
home in the future, make sure you check with the appropriate state authorities
about transportation and zoning regulations. States have restrictions on weight,
size and width that may prevent you from moving your home. If you relocate, make
sure you use a professional transporter; never try to move the home yourself.
It's also important to check the climate zone maps for your home. These maps tell
you the wind, snow and thermal zones for which your home was constructed. Use
them to determine whether your home is suitable for the new location you’re considering.
The actual overall costs connected with moving are another consideration. In
addition to transport expenses, which include licensing fees to take your home
through a state, you'll have to pay for a new foundation, installation, and utility
hook-ups.
For more information about manufactured homes contact your local InterNACHI member
at
www.InspectorNow.com
